oldskull's Levin
12-23-2008, 03:10 PM
Post: #291
oldskull's Levin
oldskull Wrote:actually there was few rust spots when I bought the car. And now we found out that the previous owner dont weld new metal where serious rust is. He just take thick plaster on it. and the rust come back again like aussiefan mentioned. that is a nast way to "solve things" too bad it happend to your car.. but good that it is beinig solved!! +1 @ ivan141 What is a nice treatment against rust except to cut it out and weld a new part in ??? are there anny other and better products available? Cheers, Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
12-23-2008, 03:26 PM
Post: #292
oldskull's Levin
jup, cut out and weld new pieces in!
![]() there is no other way, kurust/noverox is just to stop the proces for a few months untill the real repair is caried out. if it's only surface rust you could get away with sanding/grinding it away and paint. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
12-23-2008, 03:42 PM
Post: #293
oldskull's Levin
oke..
but for hard te reach places ? ?? p.s. are we talking to each other the same time on different Fora Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
12-24-2008, 12:27 AM
Post: #294
oldskull's Levin
hard to reach areas: cut a bigger hole, weld and then weld the hole you made
12-24-2008, 01:56 AM
Post: #295
oldskull's Levin
Gtsi-R Wrote:oke.. Best way, to strip car apart and dip the whole chassis in acid baths. Everything except iron and steel melts, that means all plastic/aluminium/rust ... leaving you with "swiss-cheese-like chassis I've seen few examples on Exporer/Discovery. It does great job on rust, on easy and hard to get places Expect the fact that neither one owner expected his belloved car was in that bad state . Reality check
12-24-2008, 12:44 PM
Post: #296
oldskull's Levin
acid gets into places where it will not get out, eventually eating it's way through protective layers and becoming a cause of rust. Not the best method to strip paint. There is one where you dip the car in a solvent (called loog in dutch, lye or something similarly sounding in english), that is supposed to be better. This will only remove paint, so you can spot the rust easily and remove it yourself.
12-25-2008, 10:40 AM
Post: #297
oldskull's Levin
Don't know right names ant technology but from what i remember, chassis goes through 3 baths. In the first one, everythings but steel dissapears, second one is for cleaning and the last one is for protection.
There where no unwanted aftereffects, at least not on TV
12-25-2008, 11:15 AM
Post: #298
oldskull's Levin
Acid dipping is hugely expensive, there are a few places in the UK that offer the service.
Remember the guy on club4ag that powder coated his shell, it will take that a while to rot. An 86 is for Life, not just for Christmas |
03-22-2009, 07:19 PM
Post: #299
oldskull's Levin
Some jobs have been done on my car. Yesterday we started to primer some parts. they look great only I seen some more work to do to get the primer ready before paint them. Found some really bad rusts when we removed the front left fender. But my mate said it can be done. I hope he is serious about that.
I did buy a Recaro seat from Marktplaats and it is mint and cheapppp Very happy with it.
03-24-2009, 12:24 AM
Post: #300
oldskull's Levin
On which spot did you have rust then? Near the pedalbox?
User(s) browsing this thread: 16 Guest(s)
. Reality check
![AEU86 AE86 - oldskull's Levin [Image: AEU86 AE86 - oldskull's Levin]](https://www.aeu86.org/sticker-banner-468.gif)
