o2 sensor and rough idling
10-30-2008, 02:14 AM
Hey this topic mite have been talked about before.
On my ae86 trueno i see theres 2 sensors one near the top of the exhaust manifold and one near the bottom of the manifold. Its just that the bottom one is cut off and im wondering if i need it. At the moment it runs abit rich as i can smell the fuel coming out of the exhaust and im worrying about emissions when i MOT it near late december time. Also when the engine is warm or after a thrashing it struggles to idle properly it dips from 900rpm down to 5-600rpm and bounces back up. Ive cleaned the filter, checked vacuum lines and they seems to be fine any ideas ??? will try and get pics up on the sensors |
10-30-2008, 07:41 AM
the second lower o2 sensor looking things is actually exhaust temp sensor for your cluster, has nothing to do with ecu.
Running rough when warm could suggest busted plugs and/or leads Idle hunting can be a dirty throttle body, or dizzy out but a tooth. Steve.....this is sparrrrrtan |
11-12-2008, 06:53 AM
hi there..
i'm new comer, my engine had similar problem with u alex, but my check engine directly appears when the engine was warm, i've check with my friend,they suggest to change new that sensors |
11-19-2008, 04:01 PM
hmmm.... ic ic my lights was fine nothing came on when running
the porblem i found now is that its something to do with eleco or ground (i think) as it gets worse when i put radio, heater and lights on i have bought a grounding kit with voltage stabilizer just waiting for a gd time to put it on |
11-19-2008, 04:02 PM
11-26-2008, 07:52 PM
installed earthing kit with voltage stabilizer and idle is still rough moving up and down alot only when i put the front fogs on when they are off its less rough
plugs was new 6 months ago so gonna change leads, dizzy cap and rotor arm and see |
11-26-2008, 08:06 PM
don't forget to check your TPS setting :wink:
AE86 FANATIC!!! |
11-26-2008, 08:08 PM
how do i do that ? im abit of a noob lol
| map sensor cheating? | fdsjakl890 | 8 | 4,359 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 9,938 |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 25,182 |
09-06-2014 05:47 PM Last Post: izanagi |
| Hall sensor | totta Crolla | 7 | 11,332 |
02-28-2014 10:07 AM Last Post: Ivan141 |
| Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 14,687 |
10-25-2013 05:13 PM Last Post: Apsogos |
