need help urgently!!!
09-26-2009, 05:02 AM
i've taken off my axle on my car, coz i've bought another axle with lsd, i want to change to the newly bought lsd diff.
now that old shaft got 23 spline which is same as the new one, but the difference is that my on car shaft is thinner than the one qith the lsd, can i just put the lsd diff in with using my old shaft? coz the one come with lsd comes with drum brake, where my old one with disc brake but without lsd...
i hope i've made the question clear, as i'm working on my car now....
any reply is deeply appreciated.
Thanks
09-26-2009, 08:37 AM
What car?
Philip
09-26-2009, 10:01 AM
lolali Wrote:i've taken off my axle on my car, coz i've bought another axle with lsd, i want to change to the newly bought lsd diff.
Thanks
I think you have some early/late shaft problems (24 VS 25mm diameter?)
They are not interchangable though..
good question cannabolic, what car?? and where are the axles come from?
09-26-2009, 07:12 PM
cannabolic Wrote:What car?
Sorry, forgot to mention that, both from AE86's axle....i've somehow got the answer from some source else way, they're not interchangeable somehow.... Sad
09-26-2009, 11:01 PM
Well, it's like ZDoman said. Zenki/kouki and their differences.
But you say you got drum brakes. AE86 never came out with drum brakes.
It's maybe a supra/celica-supra axle. Am not sure though.
One this is fo sho, if it's with drum brakes it's not AE86. Maybe it's some kind of strange diff/shaft combo I've never heard of.
You got any pics of the whole thingy??
Check if it's been modified. Spring nest/shock support/4-link re-welded
Philip
09-26-2009, 11:11 PM
If the axles are the same length, and have the same (large) bearing,
you could swap the diff and the axles over ??
Cheers... jondee86
09-27-2009, 07:22 PM
cannabolic Wrote:Well, it's like ZDoman said. Zenki/kouki and their differences.
AE86 might not come with drum brake, but AE85 does, not so sure of what car the axle is from, but it look definitely an ae86/ke70/te71/te71/ae70.....it's the same setup as AE
09-27-2009, 07:24 PM
Cheers... jondee86
As far as i know, it could be swap only if the diameter of the wheel shaft is the same, n same number of spline of course.
09-27-2009, 07:43 PM
Cheers... jondee86
I think is like jondee86. large bearings are the same in zenki/kouki even though the diameter is different. And the diff of course needs to be swaped.
But like i said, the whole casing is not from an AE86. Maybe the shafts.
Philip
09-28-2009, 11:07 AM
lolali Wrote:AE86 might not come with drum brake, but AE85 does, not so sure of what car the axle is from, but it look definitely an ae86/ke70/te71/te71/ae70.....it's the same setup as AE
The AE85 axle is different: its diff is 6.38 inch instead of the 6.7 inch. But I already said that in the other topic... Wink
It could be a Carina axle: the A4 and A6 Carina with live axle has exactly the same axle as the AE86 with drumbrakes. I know of a Romanian hachi which has the Carina axle swap due to shortage of parts.
[Image: AEU86 AE86 - need help urgently!!!]
  Windshield. Need Help. Roma_trueno 13 23,823 02-02-2026 02:19 PM
Last Post: totta Crolla
  Need help installing replica "OEM" sideskirts sheppardpat47 1 483 01-30-2026 11:16 AM
  Need help identifying this! takumi_mt 4 2,769 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 6,545 02-18-2022 10:42 AM
Last Post: ps13michi
  Need some help DJexor 4 7,222 03-13-2018 05:37 PM
Last Post: pack
