need help combining 4AC block with 4AG head
07-05-2007, 10:36 AM
hi
i swapped my heads on my 4A Block the 4Age fits 100%
Swapped in Block :
4A crank to 4AGE crank
4A pistons to 4AGE std piston
4A Flywheel to 4AGE flywheel
so basically all in the block was upgraded <engine>
(1) i got a 4AGE distrubutor will it work as i will be running a weber carb
(2)can i use the norm 4A alternator
07-05-2007, 11:24 AM
1. yes, but will work a bit different (get stable vacuum signal)
2. no because 4AGE alternator pulley is different (at least from 4AC version)
07-05-2007, 12:07 PM
so the 4AGe will then work but one sum mod i also still got the old 4A-C
ok as i checked the pulley both on 4AGE pulley and alternator the same
07-05-2007, 01:13 PM
Max_toy Wrote:ok as i checked the pulley both on 4AGE pulley and alternator the same
The pulley on alternator are not the same.
4AC alternator (at least the one I got on 4AC) is older construction, a bit larger and on the wrong place on the block than 4AGE (in AE82). I think that would be problems fitting 4AC alternator on 4AGE.
Rather get one from 4AGE (or 4AFE or 3SGE, they are the same)
On the pic; on the left 4AC (and the same on 2T), on the right 4AGE (the same one is on 4AFE and 3SGE)
[Image: AEU86 AE86 - need help combining 4AC blo...h 4AG head]
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
07-05-2007, 01:41 PM
ok i see my look more or less the same ...so i have to shop for a new maybe as the one that came with that block ...will see if i can make a mod on it if possible if not will get one either 4afe cuz to 4AGE parts here is like looking for gold
still got my engine standing in my room going to drop in car when i get the free moment ...think i will try fitting the alternatoer on to see what goes
thanks
07-08-2007, 09:12 AM
Update
got everything in and dropped 4AGE into my car .connected all my water pipes fitted my intake with weber ...slapped on my branch but one last think
so i am using a weber carb i was given a 4AGE distrubotor how do i connected it as the 4A-c and 4AGE is different please help ,,,
07-15-2007, 08:33 AM
hi me again
i got everything in my car ..and it runs smooth
used my old 4AC alternator butmod that bracket
It works Smile
07-15-2007, 10:42 AM
You used 4AC alternator+modified 4AC bracket ? How about belts - isn't your alternator pulley different than crank pulley ?
07-15-2007, 10:49 AM
nope its the same ..and the belt ...so it all work cool ...just have small problem with distributor but in the processof finding solution
  Need help installing replica "OEM" sideskirts sheppardpat47 3 1,180 08-09-2026 12:46 AM
Last Post: sheppardpat47
  Windshield. Need Help. Roma_trueno 13 25,639 02-02-2026 02:19 PM
Last Post: totta Crolla
  Need help identifying this! takumi_mt 4 3,365 04-05-2024 09:17 AM
Last Post: takumi_mt
  Question about 4AG 20v Engine Block CHACAMAN 1 3,412 06-10-2022 05:17 PM
  TRD ECU need help ps13michi 5 7,241 02-18-2022 10:42 AM
Last Post: ps13michi
