need help combining 4AC block with 4AG head
05-16-2007, 10:21 AM
compression ratio as far as i knw
05-16-2007, 10:27 AM
so do i need to change the piston or can i leave it as it and just pop on the head on the 4AC block with out any problems would it give me major problems ....
05-16-2007, 10:50 AM
Major problems - I think - no.
Are you from USA ? On Ebay you can buy CHEAP new 4AGE pistons, get rings also and make 4AGE even with 4AC conrods and crank. It will work for everyday use. |
05-16-2007, 11:05 AM
No i am in south Africa... i and the piston here is a bit pricey
05-16-2007, 12:05 PM
Changed the topic title to something a little more meaningful
![]() Max, you found a 4AG head but no 4AG block? How about getting a 7AFE engine and putting the 4AG head on that? : http://www.club4ag.com/faq%20and%20tech_...d%207A.htm http://www.aeu86.org/index/engine-4age-t...post=60902 Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
05-16-2007, 12:37 PM
Max_toy Wrote:No i am in south Africa... i and the piston here is a bit pricey Okay, try to get some like these: http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...:IT&ih=007 There are also Clevite brand pistons (proven good enough) and rings at similar prices. I hope you can buy them from South Africa ? |
05-28-2007, 07:41 AM
hi
i was able to pick up a set of 4Age pistons and a crank for free... and all in a good state... so this all will pop in to my 4A-C block and off we go |
05-28-2007, 07:44 AM
so this is what i have
> Bluetop 4Age head > manifold >all gaskest >inake weber manifold >weber carb 32.36 >4Age pistons + crank >rings + bearings >4A-c block |
05-28-2007, 09:52 AM
So you must find conrods only.
05-28-2007, 10:53 AM
sorry forgot about that got the conrods ...
| Need help installing replica "OEM" sideskirts | sheppardpat47 | 3 | 1,427 |
08-09-2026 12:46 AM Last Post: sheppardpat47 |
| Windshield. Need Help. | Roma_trueno | 13 | 26,452 |
02-02-2026 02:19 PM Last Post: totta Crolla |
| Need help identifying this! | takumi_mt | 4 | 3,639 |
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 3,528 |
| TRD ECU need help | ps13michi | 5 | 7,561 |
