longer wheel studs
02-15-2011, 05:03 PM
longer wheel studs
Hi,
since I´m taking the axles out to fit my new TRD LSD and I probably want to change the wheel studs for longer ones.
Has anyone done that before and could tell me the press fit diameter on AE86 axles, I think they´re 14,2mm but I´d like to confirm...
Thanks!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
02-15-2011, 11:16 PM
longer wheel studs
I'm not sure about the exact diameter but I can tell you that you need
to be careful that the splined part isn't so long that it protrudes beyond the hub face.
I fitted some that were like this and the wheel nuts would not tighten properly.
Apparently Landcruiser studs fit and they are longer but I have yet to find a part number for them.
02-16-2011, 01:31 AM
longer wheel studs
try here...
i found many answers here also...
http://lmgtfy.com/?q=ae86+longer+studs
Tongue
02-16-2011, 01:32 AM
longer wheel studs
Some information here...
http://www.toymods.org.au/forums/showthr...ost1033923
Cheers... jondee86
02-16-2011, 05:32 AM
longer wheel studs
Thanks for pointing me in the right direction!
Little bit more investigation and I should find what I need, thanks. Hurray!
02-16-2011, 12:25 PM
longer wheel studs
http://s-86.com/s-wstuds.html
MR2 SW20 (MK2) studs for me !
02-16-2011, 01:13 PM
longer wheel studs
I've read the IS300 studs fit also. You can also use extended IS300 studs for uber long studs.
My Hachi Roku
02-17-2011, 09:57 AM
longer wheel studs
Wave
http://www.aeu86.org/viewtopic/where-to-...el%2Bstuds
Fun is not the straight line!
  ARP Head studs in a N/A engine, necessary? Jimmi The Kid 13 16,810 02-04-2013 11:27 PM
Last Post: Jimmi The Kid
  Longer 5th gear into T50 stratosTRD 3 5,437 06-16-2011 08:36 PM
Last Post: stratosTRD
  Longer studs Eric 4 6,635 04-29-2011 07:35 AM
Last Post: Eric
  How to fit rear wheel studs without removing the shafts? Slipangle 3 5,609 11-19-2010 10:29 PM
Last Post: Slipangle
  Longer Tie rod / steering ends meshin 2 6,557 11-10-2010 01:57 PM
Last Post: meshin
