lntermittent starting
07-24-2021, 05:15 PM
l've not investigated this issue yet and wondered if anyone has experienced this problem on an AE86 before.
Sometimes turning the key to start the engine there is a 'click' from the starter, other times it is fine. Maybe happens once in twenty starts. Battery is good as are the connections to both starter and battery. I'm wondering about the ignition switch. Any help or thoughts appreciated, thanks. An analogue brain in a digital World |
07-25-2021, 04:44 AM
I can't remember from the top of my head but look through the first couple of pages of my Globetrotter thread. I had a similar issue. I think I took the starter apart, cleaned, reassembled, tested it according to the manual and put it back in after.
AE86 ex-daily |
07-25-2021, 02:15 PM
Thanks Bean l'll go check that thread.
l know that the starters don't like heat much. An analogue brain in a digital World |
07-25-2021, 06:24 PM
Does it happen only with either cold starts or hot starts?
07-26-2021, 09:19 AM
It seems random banpei but l will keep a check over the next few days.
08-30-2021, 12:59 PM
I had the exact problems you are experiencing when I first had my Corolla. Sometimes, it starts on the button and other times it didn't. Also, when I drove my car and then stopped and tried to start the car again, it was like dead. I had to wait until the car cooled down and then it started up again. It was so frustrating.
The problem lies down to contacts wearing out on the power feed to the solenoid. I followed the guide by SQ Engineering by installing a 4 pin relay. This has overcame the problem and I never had that problem since. Read this. https://www.sq-engineering.com/tech-arti...ter-motor/ Hope this helps. There is only one true Nismo at AEU86 |
08-31-2021, 06:21 PM
Nismo, sorry l missed your post.
Thanks, l'll check that out. An analogue brain in a digital World |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,339 |
| JDM trueno not starting. need help! | kazi | 8 | 11,512 |
| 20v Starting Issues | mad.matt | 10 | 15,283 |
09-24-2014 12:44 PM Last Post: pack |
| starting/electrical issues | Jezza_hr | 14 | 22,924 |
12-21-2013 05:45 PM Last Post: Apsogos |
| HELP!!! hard time starting | drift | 36 | 41,554 |
04-23-2012 01:40 AM Last Post: drift |
![AEU86 AE86 - lntermittent starting [Image: AEU86 AE86 - lntermittent starting]](https://www.aeu86.org/sticker-banner-468.gif)
