lack oil pressure - dead engine? Please help
06-21-2005, 12:32 PM
Few days ago I was crusing in my ae86 on a highway.
5th gear, 140kmph, around 5000rpm. I noticed that my oil pressure gauge was near the low sign. I started to slow down. As I slowed down, the oil pressure was falling lower and lower, until it stayed on 1/4 od the gauge, check engine light goes on. As I stoped i heard strange mechanical noise from the engine. Also engine would not idle, just dies. It took 30 sec for me to slow down. So I check the oil level, it's ok, enough coolant, no overheating, but dead engine. I looked bit in to the radiator, looks like clear coolant, no oil, so headgasket looks OK. Called the towing truck and towed AE86. I didin't want to drive it. So, I asume a) spun bearing on crankshaft b) oil pump What should I do/check first? Can I remove the oil sump from the engine without taking the engine out? Drifting - best fun you can have in your car with your pants on! |
06-21-2005, 04:48 PM
man thats sad to hear.
yess you can take of the sump without rasing the engine. You can even change bearings - but it´s a hell of a job. when my first engine went dead is had started to sound a lillte knackering noice from the rod-bearings. even after i took the bearings out - they seemed "ALMOST" ok. minimal damage had caused a noice like a bulldozer on asfalt doing som drifting ![]() i would change the bottom end - but only if you can to 100% see that the head has NOT taken any damage - Specially the camshaftbearings. mine were totally destroyed BTW - you do not know for how long you had been driving with LOW oilpreassure then ??? Kris ![]() I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
06-21-2005, 05:53 PM
Zax, its not a problem atall changing the conrod bearings without taking the engine out. You need to remove the gearbox-brackets between engine and gearbox (one on each side of the engine) to get the oilpan down. It took me approx. 1½ hour to get it ready for new bearings.
The crankshaft bearings cannot be changed without pulling the engine out of the bay... But i would guess, that your oilpump has died and that had caused the lack of oilpressure. Youtube Myspace and I´ll Google your Yahoo |
06-22-2005, 08:27 AM
Low oil pressure and knocking noises - my guess would be bearings. But the check engine light and engine dying is a bit weird- is that normal with dead bearings?
02-14-2006, 11:27 AM
Sorry to dig this sad old topic, but to inform everyone: I had 2 spun bearings on big ends.
Hope this information will not be useufull to anybody else. Drifting - best fun you can have in your car with your pants on! |
02-14-2006, 12:06 PM
Hahah, Zax dude, it took you half a year for that huh
![]() Go give the white comet a new engine! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 8,621 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Oil leaks - Help | Bojack | 4 | 6,702 |
10-19-2018 01:34 PM Last Post: Dave W |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 23,631 |
Carb question please help | MIGGZFSU | 3 | 5,599 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
Whining noise HELP PLEASE | izanagi | 10 | 14,103 |
03-26-2015 06:48 PM Last Post: Komba |
