k40 to T50 worth the effort?
02-20-2007, 12:49 PM
Tell me about how 'good' a T50 is
I've got almost no experience in driving a car which has a T50 box, but i've found a bellhousing for sale to switch to a T50 box on my k series engine. And since i managed to break 2 K40 boxes in 1 year and still missing the 5th gear, it sounds appealing to me to try and fit a T50.
Is it worth the effort (switching to hydraulic clutch, different driveshaft, probably cutting a new hole in the floor for the shifter etc. etc.) to switch to a T50 box?
I always liked the K40 box, it's a good box i think, but i think i'm to brutal for it Blush
And with the new engine i'm (still....) building, a little bith more strength ain't bad i think Smile
02-20-2007, 01:10 PM
Second synchro is weak (known issue) and the fifth gear is not that much longer than fourth, so dunno if it's worth. Undecided
But then again I have never driven with a K40. Tongue
[Image: AEU86 AE86 - k40 to T50 worth the effort?]
02-20-2007, 01:20 PM
Doctor why don't you give it a try
I think that it is better to keep your setup as it is because i think it is easier to find a K40 gearbox than a T50.
Anyway can i ask you something?You may know.
I found an LSD for sale here and i wonder if it fits my housing in my KE30.What do you think?
02-20-2007, 01:30 PM
banpei Wrote:Second synchro is weak (known issue) and the fifth gear is not that much longer than fourth, so dunno if it's worth. Undecided
my K40 allready ate 2 2nd gear synchros, but they broke apart and flew through the box taking the rest with it Sad
djkolotour Wrote:Doctor why don't you give it a try
If it's a 6" LSD it will fit, but any other won't fit. Unless you swap the complete axle over. So if it's a stock Celica/AE86 diff it won't fit sadly.
I want to be sure before i even start thinking about it, because the custom bellhousing i found is in NZ Smile
It'll cost me quite a lot before i can even begin to look out for a T50 Smile
02-20-2007, 02:02 PM
Doc,
Is a K40 that weak or where these just warn out boxes to begin with? maybe rebuild one before you wreck the synchro?Big Grin
02-20-2007, 02:04 PM
The Doctor Wrote:my K40 allready ate 2 2nd gear synchros, but they broke apart and flew through the box taking the rest with it Sad
A good reason to try the T50 then. Wink
02-20-2007, 02:05 PM
Until he wrecks a t50 by screwing its synchrosBig Grin
Which brings up an interesting topic, I need to go and find out how much it would cost to buy a rebuild kit for a T50 and see if I can rebuild a box for funBig Grin
02-20-2007, 03:37 PM
It cost quite a lot when I rebuilt mine. I'd say 200-300€ range.
02-20-2007, 03:38 PM
Dorifto, in parts or also labour?
02-20-2007, 03:44 PM
Doc, why don't you try some cheap box with detacheable bellhousing (i.e. easy to implant) ?
I'm watching some Getrag 262-264-265 ones, not bad at all ! The 4-spd box cost ~40EU here and is strong enough to be used in 633 old BMW car.
  T50 gearbox totta Crolla 3 4,172 02-25-2022 02:35 PM
Last Post: Project D
  T50 TRD gearset DidiDex 7 12,093 09-12-2019 07:36 PM
Last Post: DidiDex
  4A-GE bellhousing on a 20 spline T50 The Doctor 2 8,601 09-30-2016 03:38 PM
Last Post: The Doctor
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 8,168 11-27-2015 10:06 AM
  T50 Gearbox, Fragile ! hachirokkos 10 15,832 11-12-2015 12:06 PM
Last Post: S.K.
