TRD Head gasket P/N 11115-AE851
04-10-2008, 01:27 PM
Hello,
I found 2 TRD head gaskets in my office with the P/N 11115-AE851. I presume they are for AE86/4AGE. I searched for this P/N on TRD website and on google and couldn't found anything, however i think AE851 stands for AE86 parts. Anyone can help me or have any suggestion? Thanks, Pedro Keeping the AE86 alive! |
04-10-2008, 06:22 PM
Those gaskets are from a LOOOOOONG time ago. I have a 9/1986 TRD parts catalog.
![]() "11115-AE851 - Gasket, cylinder head 1.2mm(when torqued) material asbestoes" Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-10-2008, 09:06 PM
give us the catalogue Oldskewlboy :wink:
AE86 FANATIC!!! |
04-10-2008, 10:01 PM
i might be needing one of those
( if they are for sale )
04-10-2008, 11:32 PM
yes gon... we can make a deal on them...
I also have one of those catalogues on the attic. If it has 1.2mm is larger than the oe one, right? Keeping the AE86 alive! |
04-11-2008, 12:42 AM
good for turbo or supercharger aps!
Hmmmmmmmmm The above gasket is stock thickness when torqued. The stock gasket thickness is 1.2mm Other gaskets listed are a 1.1mm a .8mm and a .5mm
also aasbestos ISN'T desireble for boost, solid metal... or mls... is ok, not asbestos If you want gaskets for boost... SCE makes SOLID copper head gaskets upto 2.4mm thick...... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-11-2008, 11:32 AM
So this gasket is good for high compression pistons...
It should have a better resistance than the OE one... Keeping the AE86 alive! |
| Oil leak (maybe a cylinder head gasket?) | max_ae86 | 15 | 23,503 |
11-30-2013 03:59 AM Last Post: jondee86 |
| 4AGE Heat Shielding Intake Gasket | asyrigos | 11 | 29,240 |
04-01-2013 10:58 AM Last Post: asyrigos |
| Doing a 7AGE build, gasket question | Snejk | 9 | 18,481 |
07-15-2010 12:42 PM Last Post: PetzK |
| Head Gasket Replacement - Block Surface Question ?? | juantonwan | 4 | 7,783 |
06-11-2009 02:24 PM Last Post: ZDoman |
| oem head gasket thickness? | Melo | 6 | 8,853 |
05-22-2009 10:46 PM Last Post: Melo |
![AEU86 AE86 - TRD Head gasket P/N 11115-AE851 [Image: AEU86 AE86 - TRD Head gasket P/N 11115-AE851]](http://i79.photobucket.com/albums/j143/oldeskewltoy/TRDAE8682partsguide.jpg)
