howdy all from nz
06-15-2012, 05:04 AM
howdy all from nz
hey guys and gals,
my names james, im 23 from auckland new zealand
currently i own an ae92 corolla sedan gt, with a 7agze running 5psi
i would very much like to set her on fire,
one day i will own an 86 like ive always wanted but moneys tight atm
06-15-2012, 04:44 PM
howdy all from nz
lol, set her on fire? Tongue
Welcome! Wave
ハチロク
[Image: AEU86 AE86 - howdy all from nz]
06-16-2012, 01:47 AM
howdy all from nz
Yea im having big time fuelling issues
06-16-2012, 04:37 AM
howdy all from nz
What sort of fuelling issues??
06-16-2012, 04:42 AM
howdy all from nz
Over fueling and fowling the plugs. Found out its got a 4age ecu and gze intake and injectors. Ive just got a gze ecu so im hoping that will solve the problem and i need to lower the fuel pressure as its about 90psi atm
06-16-2012, 04:44 AM
howdy all from nz
sounds like a good start. if you have any more issues i hope i can help.
06-16-2012, 05:30 PM
howdy all from nz
welcome
06-21-2012, 07:13 AM
howdy all from nz
Ok so im stumped guys.
I drove this car back from rotorua. About 5 hours.
Ran horrid but didnt miss a beat except for at high rpm.
Now its running like a pig it starts and runs ok when cold seems to missfire alot though but when it gets warm it dies? Any ideas?
Btw i didnt do my homework and have gone and got an ae101 4agze ecu clever i know.
So yea any ideas would be awesome. Ooo it also idles about 1000 rpm when cold. So i think ill adjust the throttle screww a bit and see if that helps
06-21-2012, 01:10 PM
howdy all from nz
Might be the ignition coil.. quite a usual failure mode for it to work when cold and then crap out once it gets hot.
06-21-2012, 11:10 PM
howdy all from nz
ok so ignition coil, ill test that out,
could it be headgasket?
it seems to be only losing compression on #2 and #3 cylinders
  Nice to meet you all! rodri_vp 4 4,963 12-24-2021 04:56 AM
Last Post: rodri_vp
  Hail to all Patrick Ross 33 30,029 04-03-2018 12:38 AM
Last Post: Patrick Ross
  hello all greed1 7 10,131 08-11-2014 11:11 PM
Last Post: greed1
  Greeting To All Mr Beams 5 8,091 07-08-2013 11:06 AM
Last Post: Mr Beams
  hi to you all Hachi drivers!!!!!! MajkL 13 14,931 12-13-2010 03:20 AM
Last Post: Xerius
