how do i convert the digital dash?
10-16-2006, 11:32 PM
i have a japanese toyota tureno.does anyone know how i convert the dash to display the speed in mph,rather than kph?
it is a digital dash.im having the rust on the car fixed now,will post some pics very soon!
nice site btw,
regards..................[Image: AEU86 AE86 - how do i convert the digital dash?]
10-16-2006, 11:39 PM
Is it me, or is it some sort of new style to start calling trueno's tureno?Big Grin
You do know tureno was made up by some guy when they made initial D because they weren't alowed to use the trueno brand name right? Note the carpet in your picture Big Grin
As for your question, no idea how to do this conversion but I know there are little gearing units that can be bought that you put on your speedo cables that are supposed to do this. They work with the analogue dashes, not sure if they work for digital dashes but I assume they should work...
10-16-2006, 11:58 PM
thanks for th info!
im aware of the gearing mech.
but its just a simple programme to do it.it must read kph/mph to pass the road test here in northern ireland.
anyone else know?
10-17-2006, 12:02 AM
is there not a boy in the autotrader n yellow pages the work at them
10-18-2006, 12:09 AM
you'll need a digital fueltank sender (part# 83320-19725),
replace the analog oil pressure sensor with a oil pressure switch (one of a EP71,82,91/SW20/AE92/ST16x will do. Or any toyota without pressure gauge, only oil pressure light switch)
10-18-2006, 09:11 AM
Calavera Wrote:you'll need a digital fueltank sender (part# 83320-19725),
He's not going to convert the whole gauge from analogue to digital, just convert the reading on the speedometer from kph to mph. Wink
You did a conversion as well, anything on how to change the readings? Dumb question
10-18-2006, 10:13 AM
That could be an tricky one, with it being digital & all, the key might lie with the celica-supra digi set-up
11-07-2006, 01:45 AM
Bump for an old thread, someone help Fishlegs out, nobody with an answer?
(also moving this to tech)
11-07-2006, 01:54 AM
Can't seem to find anything noteworthy on club4ag about it Sad only info about hooking it up, nothing about mph->kph or visa versa...
11-07-2006, 09:35 AM
Fishlegs i might say something stupid but:
Why don't you try to find an analogue panel from a friend or so and place it just to pass the test and then put yours again in its place.
I don't know if the cables and plugs fit the analogue panel.
Cheers Thumbs up!
  Digital Dash evfan42 190 300,461 05-03-2024 06:44 PM
  Digital speedometer on stock dashboard FanIsHere 0 2,418 11-09-2022 01:36 PM
Last Post: FanIsHere
  Can you convert your 86 back too the original state? gh0st 7 5,014 04-25-2022 04:25 PM
Last Post: gh0st
  Dash Waning Lights pack 7 6,250 10-06-2021 01:00 PM
Last Post: pack
  Trueno Digital dash kph to mph Bojack 3 8,571 11-21-2018 12:27 AM
Last Post: kazi
