gze oil
07-04-2011, 12:45 PM
gze oil
Hello all
i've just replaced all the bottom end bearings on the gze. what oil do you recommend putting in and how many miles shall i use it for before changing it. The world without TOYOTAs, cant imagine it. |
07-04-2011, 04:13 PM
gze oil
Running in new bearings doesn´t require any special oil or a special procedure. Just use any 10W-40 and change after 250/300km and you should be fine.
07-04-2011, 08:38 PM
gze oil
Bearings don't need running in at all (if they wear down, you can throw them away). You could do an oil change to check for particles and such, but really it shouldn't make any difference. Run-in is only required for new piston rings.
07-05-2011, 12:11 PM
gze oil
thanks guys
07-05-2011, 01:09 PM
gze oil
Ivan141 Wrote:Run-in is only required for new piston rings. And cams... A wheel to steer the front of the car A pedal to steer the rear |
| trans oil, lsd oil change | Apolan | 9 | 20,589 |
| Oil cooler -> low oil pressure | Jan Pedersen | 24 | 37,089 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
| DLI GZE no spark | 4agetercel | 5 | 8,610 |
02-01-2013 07:05 PM Last Post: 4agetercel |
| GZE Swop with PAS & AC | Lauren | 12 | 16,891 |
02-16-2012 01:04 PM Last Post: heshan |
| Engine sounds slush GZE with VIDEO ! | Okami | 13 | 17,867 |
01-03-2012 12:12 PM Last Post: Okami |
