front strut lenght comparison problems
01-25-2011, 12:06 AM
Hi,
my AE got a coilover suspension with koni yellow struts. My problem one of them is totally fu****, there is oil everywere and I can´t pull it out to measure total length.
Luckily someone on here could sell me 2nd hand Koni to fix it temporary. (Going to buy Driftworks CS2´s as soon as its back in stock around 6-7weeks)
Since I didn´t build the suspension, I´d like to find out what was done.
I meassured 345mm total lenght of the strut body (yellow part)
and my housing is around 425mm long (bottom to top with no locking nut)
Does anybody know it that´s stock or short-stroke?
Strut housing was half filled with oil so I forgot to check if there is a spacer at the bottom.
The strut I could get does have a a strut body lenght of 400mm, wich is quiet a bit more than the 345mm I measured.
I´m not sure it will fit my housing...
So I really need your help. Dumb question
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
01-25-2011, 01:00 AM
Thats probably an AE92 or SW20 shock. aka short strokes.
I would take a drive in a car with DW suspension before buying them..
01-25-2011, 01:11 AM
I know you´re the suspension guy, but can anybody confirm?
What´s wrong with the DW CS2? I´m not using it on the road.
01-25-2011, 07:28 AM
fax0815 Wrote:I know you´re the suspension guy, but can anybody confirm?
60mm difference sounds very like ahort stroke.
Nothing wrong with the DW suspensions, had them on my S-Body - they are just a bit on the hard side but as you're not using it on the road, even if you would, there perfectlt ok.
01-25-2011, 09:20 AM
340mm is definately short stroke. Same length as the short HTSs.
DW valving for some cars can be too hard. I would try them before buying them, thats all I said.. not that there is something wrong with them.
01-25-2011, 04:12 PM
Thanks for your help!
I´ll see what I´m going to do with my new suspension, but for now I have to stick with the old parts...
Mostlikly not, but does anyone have a 2nd hand short stroke Koni yellow lying around?Confused
Or any usable 2nd hand shortstroke shocks???
I could have 2nd hand AE92 TRD yellows no proof how good they are, but I need to make an offer?
What do you think is the reasonable price? 100€?
Cheers, Max!
  Big wheel problems gh0st 16 15,819 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 5,079 08-31-2021 06:20 PM
Last Post: totta Crolla
  TUV - Strut brace pack 3 7,855 09-08-2018 08:17 PM
Last Post: d3nso
  Problems Mintex M1155 pads Dino86 9 13,351 07-04-2017 11:22 AM
  16v Bigport fuel problems Rascal21 1 6,625 07-04-2015 01:00 AM
Last Post: jondee86
