front strut lenght comparison problems
01-25-2011, 12:06 AM
Hi,
my AE got a coilover suspension with koni yellow struts. My problem one of them is totally fu****, there is oil everywere and I can´t pull it out to measure total length. Luckily someone on here could sell me 2nd hand Koni to fix it temporary. (Going to buy Driftworks CS2´s as soon as its back in stock around 6-7weeks) Since I didn´t build the suspension, I´d like to find out what was done. I meassured 345mm total lenght of the strut body (yellow part) and my housing is around 425mm long (bottom to top with no locking nut) Does anybody know it that´s stock or short-stroke? Strut housing was half filled with oil so I forgot to check if there is a spacer at the bottom. The strut I could get does have a a strut body lenght of 400mm, wich is quiet a bit more than the 345mm I measured. I´m not sure it will fit my housing... So I really need your help.
01-25-2011, 01:00 AM
Thats probably an AE92 or SW20 shock. aka short strokes.
I would take a drive in a car with DW suspension before buying them.. A wheel to steer the front of the car A pedal to steer the rear |
01-25-2011, 01:11 AM
I know you´re the suspension guy, but can anybody confirm?
What´s wrong with the DW CS2? I´m not using it on the road. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-25-2011, 07:28 AM
fax0815 Wrote:I know you´re the suspension guy, but can anybody confirm? 60mm difference sounds very like ahort stroke. Nothing wrong with the DW suspensions, had them on my S-Body - they are just a bit on the hard side but as you're not using it on the road, even if you would, there perfectlt ok. AE86 ex-daily |
01-25-2011, 09:20 AM
340mm is definately short stroke. Same length as the short HTSs.
DW valving for some cars can be too hard. I would try them before buying them, thats all I said.. not that there is something wrong with them. A wheel to steer the front of the car A pedal to steer the rear |
01-25-2011, 04:12 PM
Thanks for your help!
I´ll see what I´m going to do with my new suspension, but for now I have to stick with the old parts... Mostlikly not, but does anyone have a 2nd hand short stroke Koni yellow lying around? Or any usable 2nd hand shortstroke shocks??? I could have 2nd hand AE92 TRD yellows no proof how good they are, but I need to make an offer? What do you think is the reasonable price? 100€? Cheers, Max! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
| Big wheel problems | gh0st | 16 | 16,248 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 5,315 |
| TUV - Strut brace | pack | 3 | 8,058 |
09-08-2018 08:17 PM Last Post: d3nso |
| Problems Mintex M1155 pads | Dino86 | 9 | 13,679 |
| 16v Bigport fuel problems | Rascal21 | 1 | 6,736 |
07-04-2015 01:00 AM Last Post: jondee86 |
