ford type 9 gearbox with 4age engine
12-24-2014, 09:25 AM
Did anyone ever make a type 9 or borg warner T-5 to 3sg bellhousing?
Andrew
12-24-2014, 11:09 AM (This post was last modified: 12-24-2014 06:41 PM by Uzelac.)
(12-23-2014 01:28 AM)filh Wrote:  Uzelac : on Esa Peltonen site :http://www.esapeltonen.fi/ refering to AE86 parts the gearbox is well called Dogbox (3 models).
I already have bought a Type 9 Quaife box , short ratios , straight pinions and synchros
Yes, you are right, i've seen that.
What confuses me now is my gearbox. It should be KL, but it is synchomesh with helical gears and I don't see one like that on their website. Hmm ... Smile
12-25-2014, 11:52 PM
dog box are made with straight cut pinions , Quaife made both straight cut pinions, with dog or synchromesh engagement.
Not many details on Espeltonen site , about gearbox (ratios ? historical version?).
The advantage : it's a direct bolt on .
I guess it would be better to email him .
Phil
Filh
Save the RWD cars
12-26-2014, 12:26 AM
[Image: AEU86 AE86 - ford type 9 gearbox with 4age engine]
better pics of Toyota 4A-GE -bellhousing bolted to Ford gearbox with homemade adapter...I think I still have adapter drawings somewhere in my garage...
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
12-27-2014, 01:30 AM
very nice part
Filh
Save the RWD cars
01-02-2015, 06:13 PM
It´s not nice drawing, but it helps...thickness is about 22mm.
T=Toyota (threaded holes) F= Ford (straight holes).
Also on bellhousing must make some room for shifter shaft.
01-04-2015, 12:39 AM
Thanks S-K nice drawing, with all measurements.
I've receive the spigot bearing (for Ford type9) but it won't fit the Toyota crank.
what solution did you use ?
Thxs
Phil
Filh
Save the RWD cars
01-04-2015, 03:47 PM (This post was last modified: 01-04-2015 03:47 PM by S.K..)
If I remember correct I use a 6902RS (28x15x7) bearing.
Toyota spigot bearing is 6001RS (28x12x8 ) and then measure Ford clutch axle diam. (I think it is a15mm).
01-04-2015, 08:02 PM
many thanks , your measurements looks correct. thanks for your answer , that will help me a lot .
Totta do you have same size for your spigot bearing?
Phil
Filh
Save the RWD cars
01-11-2015, 01:02 PM
Spigot bearing problem resolved . Thanks S.K.
Beginnning with Kouki gearbox member, to adapt with Type 9 gearbox mount .
One day , one problem , I hope to get through before first rally ...
Phil
Filh
Save the RWD cars
  Ford gearbox totta Crolla 0 2,437 02-15-2022 05:21 PM
Last Post: totta Crolla
  4ac gearbox on 4age hachirokkos 2 8,196 05-24-2016 10:16 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 10,428 10-30-2013 11:18 PM
  7AGE to W58, cluth type? slowboy2 2 7,057 05-25-2013 01:37 PM
Last Post: slowboy2
  Type of carbs to suit 4ag kpretro84 23 32,312 02-09-2013 02:29 AM
Last Post: bakonick
