ford type 9 gearbox with 4age engine
12-08-2014, 11:21 PM
Hello,
I searched on forum , but didn't found what 'i m looking for... Where can i find a adaptator for the type 9 ford sierra gearbox, to fit the 4age engine, or T50 bellhousing Saw a complete bellhousing at Fensport , but I don't know what clutch fork , and what clutch cylinder must be use? I also heard about an adaptator between t9 and t50 bellhousing , keeping all the Toyota clutch system (only the Ford clutch disk needed). Any clue or help welcome , about that upgrade . Regards Phil Filh Save the RWD cars |
12-08-2014, 11:52 PM
Here is a bellhousing:
http://www.motorsport-tools.com/catalogs...lt/?q=4age Ideally you want to buy an original RM sport one as it will fit first time without issue. You use a slightly bored out Toyota release bearing carrier with the Toyota bearing. Use your Toyota fork and slave cylinder. If you are using a 200mm flywheel then you can use your Toyota clutch cover with an MGB clutch plate. For competition use Helix make a complete clutch in either 200mm or 215mm to suit. http://www.helix-autosport.com/products/...es/toyota/ A four speed Ford gearbox will line up nicely with the gear lever hole in an AE86 but the 5 speed type 9 gear lever is further back so some modification of the hole will be required. Gearbox mount can be fabricated from the AE86 one. AE86 propshaft can be modded to suit the Ford output shaft, I had this done but eventually went for a bespoke single piece propshaft. If your intention is to run a Quaife (or similar) close ratio 'box you will definately need a final drive of 5.1-1 or lower An analogue brain in a digital World |
12-09-2014, 03:00 PM
Mine Ford Type E with adapterplate and 2T-bellhousing in Ford Anglia:
http://i33.photobucket.com/albums/d61/Kl...IM1168.jpg http://i33.photobucket.com/albums/d61/Kl...IM1169.jpg Now same gearbox is in my AE86 with 4A-GEbellhousing +Escort MK2 prop.shaft andVolvo rear end... "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
12-12-2014, 12:55 AM
hello,
Thanks both for your precious informations and links. I already have the 5,1:1 gear end. And yes , it's a Quaife gearbox. It's a bit confuse about release bearing . I don't know if the Toyota clutch bearing retainer(with seal) will fit the Ford gearbox. On the Ford , it's bolted on the gearbox cast , and on Toyota , it's bolted on the bellhousing . And it's important to keep the hydraulic Toyota release cylinder and fork . In a Ford , it's a cable clutch command.. I also know the inputshaft bearing located in Crankshaft , will not match the Ford inputshaft ... A bit lost , but got two months to fix that , before next rally season Anyway thanks for helping. Phil Filh Save the RWD cars |
12-12-2014, 01:27 PM
You can get the crankshaft spigot bearing from here:
http://www.striker-cars.co.uk/rawshop/ they also show a bellhousing but you need to be a little bit careful about bellhousings as some (RM sport) were made specifically for the AE86 but some copies are, I believe, more of a generic Ford to Toyota design. There are threaded holes that allow fitment of the Toyota clutch slave cylinder onto the bellhousing and the Toyota clutch fork is used with the slave cylinder as normal. An analogue brain in a digital World |
12-12-2014, 10:38 PM
A little clearer for me now , thanks to you.
12-12-2014, 11:57 PM
(12-12-2014 12:55 AM)filh Wrote: And it's important to keep the hydraulic Toyota release cylinder and fork . Why must you keep the Toyota clutch fork, and release cylinder? On a slightly different note... (2nd option?) LEEN uses the OEM Toyota clutch fork and release cylinder when they convert the J160 6 speed to work behind the 4AGE.... ever though of using a 6 speed???
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-13-2014, 01:38 AM
(This post was last modified: 12-13-2014 01:59 AM by totta Crolla.)
I guess if you used the Lexus 'box as a 5 speed, discounting 1st gear the ratios are not bad for a rally car.
(2nd gear used as 1st would still be a bit high even with a 5:1 final drive) 1st 3.874 26mph 7500rpm 185/70/13 (5.1 F/D) 2nd 2.175 47mph 7500rpm 185/70/13 (5.1 F/D) 3rd 1.484 4th 1.223 5th 1.000 6th 0.869 116mph (5.1 F/D) ideal ?? For a 6 speed gearbox the best budget one would be the Caterham 6 speed 1st 2.69:1 40mph 7500rpm 185/70/13 (4.778 F/D) 38mph 7500rpm 185/70/13 (5.1 F/D) 2nd 2.01:1 3rd 1.59:1 4th 1.32:1 5th 1.13:1 6th 1.00:1 109mph (4.778 F/D) ideal ?? Aluminium cased, Ford fitting, 1-1 top gear and ratios perfectly suited to a 4.778 final drive An analogue brain in a digital World |
12-14-2014, 04:20 AM
(This post was last modified: 12-14-2014 04:24 AM by oldeskewltoy.)
LEEN has test fit the 6th gear from the Nissan AZ6 inside the Toyota J160... it fits and functions...
ASSUMPTION: that all the 6 speed gears MAY be interchangeable.... S15 6 speed - 3.626... 2.200... 1.541... 1.213... 1.000... 0.767 NISMO gear - 2.907... 1.989... 1.537... 1.218... 1.000... 0.862 RX8 6 speed - 3.760... 2.269... 1.645... 1.187... 1.000... 0.843 Miata 6-sped - 3.760... 2.269... 1.645... 1.257... 1.000... 0.843 J160 6 speed - 3.874... 2.175... 1.484... 1.223... 1.000... 0.869 TRD gearset - 3.106... 2.175... 1.585... 1.223... 1.000... 0.869 Oh... the new FRS/BRZ/GT86... ratios are almost identical to the Nissan offering FRS - First Gear Ratio (:1): 3.626 Second Gear Ratio (:1): 2.188 Third Gear Ratio (:1): 1.541 Fourth Gear Ratio (:1): 1.213 Fifth Gear Ratio (:1): 1.000 Sixth Gear Ratio (:1): 0.767 Once I've met my sales goals... LEEN is going to try and cobble together the J160 1st gear, the Miata 2nd -5th gears, and the Nissan 6th gear OST ratios - 3.874... 2.269... 1.645... 1.257... 1.000... 0.767 Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-14-2014, 09:34 AM
This is great news we talked about this just recently in another thread.
AE86 ex-daily |
| Ford gearbox | totta Crolla | 0 | 2,685 |
02-15-2022 05:21 PM Last Post: totta Crolla |
| 4ac gearbox on 4age | hachirokkos | 2 | 8,543 |
05-24-2016 10:16 PM Last Post: banpei |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 10,862 |
| 7AGE to W58, cluth type? | slowboy2 | 2 | 7,426 |
05-25-2013 01:37 PM Last Post: slowboy2 |
| Type of carbs to suit 4ag | kpretro84 | 23 | 33,951 |
02-09-2013 02:29 AM Last Post: bakonick |
