Reverse gear selector wiring...
08-27-2011, 07:55 AM
Does anyone have a pic of the location and connector of the reverse gear selector wires?
08-27-2011, 11:28 PM
Two male pins about half an inch apart, near the top on the lefthand side
of the box. You need the female half of insulated bullet connectors on the end of your wires, and just push them on. EDIT: Removed pic to save bandwidth. Cheers... jondee86 |
08-28-2011, 01:51 AM
Hey thanks for the post, I am looking at where it is in the chassis loom, i.e. the pin and connector where it goes after the box, the car I got to build mine up from didnt have a gearbox, and I went with a T50 now, so really dont know where the wires are in the chassis loom to make the lights go...
08-28-2011, 03:11 AM
On my car (NZ new) there is one blue wire and one yellow wire. They
run forward in the transmission tunnel and up the firewall into the dash loom (close to the washer and wiper plugs). From there they run into the big square(ish) connector on the firewall above and behind the head. From there into the interior where some magic happens to turn the reverse lights on and off ![]() Cheers... jondee86 |
08-28-2011, 04:58 AM
Hmmm others seem to say red and black and red and light blue... Ill figure it out, thanks mate.
| Tail light wiring... | Mylesmck | 4 | 3,658 |
02-02-2024 12:36 PM Last Post: Mylesmck |
| Lambda sensor wiring | sam3007 | 10 | 9,238 |
| 5th gear issue | r.ave | 1 | 4,816 |
03-14-2021 08:52 PM Last Post: Ivan141 |
| 4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 10,171 |
06-20-2019 11:38 AM Last Post: Lykowsky |
| Some wiring help needed | DJexor | 5 | 8,315 |
