do efi 4age backfire?
03-20-2013, 09:51 AM
It's probably done the ringlands
Cheapest option would be to install another engine but you might find the bores are not scored from the piston rings and you could just fit a replacement piston into your engine. To avoid this happening again check the ignition timing. Did it backfire much before you noticed the lack of power and excessive oil consumption ? An analogue brain in a digital World |
03-22-2013, 09:19 AM
duno what you guys going about ^ but the problem was intake. i had some air lick so when the throttle closes air was not shut off straight away.
03-22-2013, 04:09 PM
http://www.youtube.com/watch?v=8a4Bz6Pa4sY
I'd advise to hear it with headphones on max volume!! ![]() it backfired like this when the mapping wasn't correct. It was very funny for the first times, but it became real annoying after a few days, when you drive the car on public roads. and I think it was the thing which broke my header aswell.. |
03-22-2013, 09:10 PM
Ivan141 Wrote:where's the facepalm smiley when you need itI'll note that down as a must-have for the forum upgrade!
| What efi is compatible for swap on a carburator | mobsterk | 10 | 13,094 |
02-12-2010 02:36 AM Last Post: Chrisso |
| What does the EFI Main Fuse do? | jeenyus | 4 | 10,592 |
06-03-2008 10:47 AM Last Post: banpei |
![AEU86 AE86 - do efi 4age backfire? [Image: AEU86 AE86 - do efi 4age backfire?]](https://www.aeu86.org/sticker-banner-468.gif)
