diff oil
07-11-2008, 01:11 AM
diff oil
name of which oil i use for the diff also how do we check level???
07-11-2008, 05:19 AM
diff oil
depends what you have, if you have a KAAZ lsd use the KAAZ diff oil, if you have TRD like me use TRD FR or cusco just use redline. if you dont have a diff oil cooler just top it off till you see the oil go out, if you have a diff oil cooler after toping it off run the car around the block and jack it up again then top it off.
07-11-2008, 09:01 AM
diff oil
Oil type depends on if it is LSD or not. Any big name brand
can supply you with both. As said above... pump oil in thru the upper plug until it starts running back out... thats the correct level. Hard core drifters like to add an extra half a litre by jacking up one side and letting the oil run down the axle tube. Supposed to help keep oil in the gears during long difts in one direction Cheers... jondee86 |
07-17-2008, 01:54 AM
diff oil
Also consider using LSD additive from GM, they sell it for the Chevrolet Corvette.
07-17-2008, 09:18 PM
diff oil
If not using LSD: 80W90
07-17-2008, 10:48 PM
diff oil
For LSD use 75W140. There is one from Castrol for example.
Greets raki http://www.sg-rallyesport.de |
| trans oil, lsd oil change | Apolan | 9 | 21,376 |
| Oil cooler -> low oil pressure | Jan Pedersen | 24 | 38,653 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
| Urgent replies needed DIFF OIL + refresh | Okami | 6 | 8,321 |
06-17-2012 09:56 PM Last Post: Okami |
| What Diff Oil For a Clutch plate diff? | jamieae86 | 10 | 17,624 |
12-16-2011 11:14 AM Last Post: bakonick |
| 4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 10,421 |
10-01-2011 09:47 AM Last Post: demogun |
![AEU86 AE86 - diff oil [Image: AEU86 AE86 - diff oil]](http://img845.imageshack.us/img845/1082/capturar01.jpg)
