corolla idles way to high HELP PLEASE
11-30-2011, 05:04 PM
Ok, so it´s different.
3 things I suggest to check:
Have you you played with the idle adjusting screw on your carburettor? Does the idle change?
Check the face of the sparkplugs? If its white you got an airleak somewhere in you intake.
Unlink the throttle cable, an try to push in and out on the carbs end, does it move alright or gets stuck (spliced cable)?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
Messages In This Thread
[] - robokill - 11-30-2011, 08:49 AM
[] - 86_ae86_coupe - 11-30-2011, 09:47 AM
[] - fax0815 - 11-30-2011, 03:26 PM
[] - 86_ae86_coupe - 11-30-2011, 03:46 PM
[] - fax0815 - 11-30-2011 05:04 PM
[] - 86_ae86_coupe - 11-30-2011, 09:34 PM
[] - allencr - 12-01-2011, 01:44 AM
[] - Uzelac - 12-01-2011, 10:05 AM
  Blacktop 20V high idle Bravothreezero 2 308 08-10-2026 04:58 PM
Last Post: ondafly
  High-beam warning lamp Mylesmck 4 4,387 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 5,915 08-30-2022 07:11 PM
Last Post: Power_uP
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 3,942 05-10-2021 01:02 PM
Last Post: Project D
  4AGE 16V engine overheat when at high speed chenfon 32 37,692 12-31-2020 06:39 AM
Last Post: chenfon
