coilovers advice
05-16-2013, 08:09 PM
coilovers advice
My advice to you is to save up your money and when you have enough sale this set up and go for greddy, tein or the most affordable one Megan isn't bad for dd either. You can't go wrong with those set up!!!
05-17-2013, 11:14 PM
coilovers advice
Spitfire Wrote:I'm using a longstroke setup with 5.2 kg/mm and yellow Koni's at
the front and its way too stiff on broken roads. I had 3.8's before
and it was a lot more comfortable and still extremely fun to drive.
This man speaks the truth...
Cheers... jondee86
05-21-2013, 10:18 PM
coilovers advice
Cheers... jondee86
Konis will do no good for comfort imo. Get some better dampers and it will change a lot. Problem as I see it is that Koni don't adjust both bound and rebound. To keep the car stable you end up with dampers set to something that is harder than what you really want.
[Image: AEU86 AE86 - coilovers advice]
  Brake advice - master cylinder mannix20vt 12 18,271 08-21-2017 03:21 PM
Last Post: Project D
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 7,851 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 6,044 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 31,724 04-04-2017 02:40 AM
Last Post: hachirokkos
  Has anyone tried BC Racing coilovers? AlexKTM 9 15,052 09-05-2016 12:28 PM
