clutch pump on the geaboxx
03-21-2013, 08:57 PM
If the clutch slave cylinder is found to not be the problem, then check the master cylinder push rod. You need 1mm of free play in the push rod for the master cylinder. If you pre-load the master cylinder piston, it will cover up the return port in the cylinder and not allow the slave cylinder to retract. The adjustment is at the top of the clutch pedal arm. Dave W
03-26-2013, 09:33 AM
Project D Wrote:I believe what he mean is when the pedal is all the way up the clutch stay disengaged (or not fully engaged)
yep this is what i mean
i have orderd a new one i will post pics of the old one
but the problem is fixt now i have the right one ;dBig Grin
me happy
  20v BT - which oil pump? Mylesmck 4 4,511 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 8,289 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 7,346 10-16-2017 07:11 PM
Last Post: jdm86gtz
  4age smallport oil pump in bigport engine? ditn 2 9,314 12-06-2014 08:10 PM
Last Post: ditn
  Oil pump question megabob 2 5,708 03-05-2014 05:37 AM
Last Post: oldeskewltoy
