changing suspension
10-22-2006, 06:36 PM
changing suspension
He all!
I'm looking for a better setup, it's now drifting only! (It's only soft setup and currently not changeble). But when I want to install other coilovers I got a problem with the height. Do you have an advise what to do? If I lower them the same as the old coilovers I have 1 cm play in the top. See arrow in the picture. |
10-22-2006, 07:24 PM
changing suspension
What exactly do you have now..is the picture of your current setup? What did you mean by the "soft" part? Springrate to low?
10-22-2006, 09:00 PM
changing suspension
The shocks under the trueno are to soft and not adjustable.
But if I install the T3 coilovers I have some space between the spring and the camberplate (only if i lift the trueno). So I think I have longer shocks in the T3 coilovers then the tein set. Is it a problem to have 1 cm space between the spring and the top of the coilover? |
10-22-2006, 09:02 PM
changing suspension
Hey Toypower!
Can you please send me a link, where did you get this suspension and ca n you please tell me, how much did you pay for it? Do you have it for whole car from Eibach? |
10-22-2006, 09:08 PM
changing suspension
added another pic
changing suspension
http://www.technotoytuning.com has this nice set.
10-22-2006, 09:11 PM
changing suspension
Just a guess Onyx, but try Techno Toy Tuning
@toypower: Check the length of the struthousings, maybe one is shorter. The cm difference is not a terribleproblem, but you will fail MOT..two possible solutions are: get a pair of longer springs with the same springrate or get a pair of helpersprings (available from whiteline for the ae86, but in reality almost any set will work. A wheel to steer the front of the car A pedal to steer the rear |
10-22-2006, 09:26 PM
changing suspension
I see. I didn`t check their web properly.
Guys, I admit I am real rookie on that. If I would like to have this suspension on my car, what else do I need to order to let it work? Or is it possible just to "get and change"? Will it fit in chassis just like that? I think not. So far, expected spendings are 600 + 750 dollars for both sets. What else? ..as I said, I am really rookie. |
10-22-2006, 09:33 PM
changing suspension
It should just bolt in...if you want to know exactly what is possible and needed, take a look at this sites faq..I think you'll find it answers most of your questions.
By the way..if you look at the T3 pricing inc shipping, take a look at companies as LEDA, GAZ and intrax as well...similar pricing, but some offer awesome features. @toypower...same springrate should be softer springrate..so better get the helpers..Do you have any pics of the old setup? Partnumbers etc? A wheel to steer the front of the car A pedal to steer the rear |
10-22-2006, 09:58 PM
changing suspension
The old setup has nice TEIN coilovers. But I think the shocks must be
replaced. So I will take these apart and find some better shocks. |
| Changing distributor when carb 4age | izanagi | 14 | 21,352 |
07-04-2016 03:27 PM Last Post: Uzelac |
| Changing propshaft bearing. Anything I need to know? | Lauren | 5 | 11,097 |
04-15-2012 02:12 AM Last Post: krullibull |
| changing diff ratio, broken LSD??? | fax0815 | 6 | 10,075 |
09-06-2011 08:19 PM Last Post: fax0815 |
| changing from electric moter windows to winders big job? | irish ae86 | 5 | 8,482 |
03-31-2011 08:39 PM Last Post: Dogger |
| time for changing my transmission | mark | 5 | 6,845 |
01-24-2006 09:21 PM Last Post: totta Crolla |
