can I install a lamda sensor?
05-25-2009, 06:45 PM
i own a 84 2 door Levin and my question is if i can install a lamda sensor and how?
how about a map sensor? |
05-25-2009, 10:24 PM
If you can get the ECU from an early JDM AE86, you can run both
the lambda sensor and MAP sensor. What I don't know is if the plugs match up, or if they have to rewired. Some early Euro spec ECU's use MAP but not O2... and ASFAIK some run AFM and O2. There are different combinations according to the market in which the car was first sold. Cheers... jondee86 |
| Can Wing Mirror Glass be Replaced? | chrisae86 | 4 | 3,552 |
10-05-2025 11:09 PM Last Post: chrisae86 |
| map sensor cheating? | fdsjakl890 | 8 | 3,260 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 8,849 |
| Can you convert your 86 back too the original state? | gh0st | 7 | 6,123 |
| Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 14,860 |
12-19-2021 11:58 PM Last Post: gh0st |
