bigger engine??
01-18-2006, 01:49 PM
Post: #51
bigger engine??
cheers for all the replays people..!!
an your rite ian it is becoming very intresting topic!! sorry havnt replyed in a while havnt got a chance to!! so wat alls required for a 4agze conversion?? and any 1 any pics of this work being carried out.. cheers for the help!! |
01-18-2006, 03:55 PM
Post: #52
bigger engine??
Its a simple enough operation I think
Build up a bottom end (4age) using 4agz pistons, rings etc, might as well do the crank bearings, or use a 7afe bottom end, you can get custom pistons made handy, then use an ae92 late spec head, bolt on the supercharger kit (compressor etc as shown in pic earlier) wire it up and off you go far cheaper than a 4agz, esspecially if somethink goes wrong, & you know what you getting as the bottom end is rebuilt, heads are easy to find. Runs off the standard ecu. Advantagous over a turdo, you have constant power on tap, no lag or hassel with turbos Id say its a good option over a turbo set-up but it all depends what you want An 86 is for Life, not just for Christmas |
01-19-2006, 08:32 PM
Post: #53
bigger engine??
how about the mazda miata 1.8 ?
01-20-2006, 12:02 AM
Post: #54
bigger engine??
Heavy metal engine, but holds boost very well. Stock engine is good up to 240-250 bhp. Gearbox is very sweet, short throws, very positive feel..
I would only consider one of these in combination with some form of boost.. A wheel to steer the front of the car A pedal to steer the rear |
01-21-2006, 06:19 PM
Post: #55
bigger engine??
I thought about the Miata swap in a AE86
mainly because HKS makes a SMOG legal turbine kit for it Vewry important for us California's the engines are very cheap here in the USA as well just as cheap as a 4AG Locally they cost $350 a miata parts car can be had for $500~1000 I belive the HKS turbine kit is about $1300 then all you would need is engine mounts, trans mount, and a custom drive shaft all in all probably about $5000 worth of parts but for $5000 you can do a lot better Max [email protected] |
02-23-2006, 04:17 PM
Post: #56
bigger engine??
Ian.G Wrote:I think the crux of the problem is smaller NA engines wont make stupendous power - they are limited by capacity and have to make their power with revs. Make's lots of sense this post. Honors 'there's no substitute for cubic inches'. And a larger capacity engine probably improves engine life due to more torque on tap at lower revs. Engine doesn't need to be reved as much as a smaller engine. This leads to lower average piston speeds which prolongs engine life. Small displacement engines as said feature low torque especially at low revs. This is mostly due to a small stroke. Small stroke leads to slow air speeds through manifold and cilinder head and in general doesn't promote volumetric efficiency. This lowers specific torque figures even further than you would suspect from the lower capacity alone... A turbocharger or other supercharging device equalizes things a bit by promoting air speeds in the intake and cylinderhead. (Bigger volume of air in same area gives higher flow rates and higher air speeds.) And as a further bonus more mixture burns longer giving the crankshaft a longer 'kick'. Higher cylinderpressure over larger amount of degrees crankshaft. So bigger and/ or supercharging devices deliver massive amounts of torque. Which isn't always appreciated. This imho has nothing to do with the engine but everything with the chassis and drivetrain. As an example a standard Dodge Ram SRT-10, which features an enormous 505 cubic inches of displacement and has low down grunt who makes every other engine feel like a moped, has a very nice chassis setup. You can throw the car around like it's a 1600 pound hatch. Virtually no lift off oversteer and some mild understeer if you throw it into a corner. Only when you take it to the absolute maximum permissible speeds the snake bites with gargantuan drifts, sudden lift off (and braking) oversteer. But all very controlled, and fun for a 4500lbs. - 430 wheel horsepower monster car... (Sorry I'm going off topic... :wink: ) Anyone wanting to see this monster attend my next dyno shoot out in Goes (The Netherlands). Or watch this video (Sorry dyno only. No street action available at this time.)(Prototype in actie ) Now we bolt on a Paxton centrifugal supercharger boosting at 7psi and a full exhaust system with headers. Power leaps up to 620 wheel horsepower and wheel torque goes up to 880Nm.. (No typo's here My point is that you have to modify the chassis to cope with the increased wheel torque. This to offer sufficient grip and traction to be able to utilise the potential increase in speed. Nothing new, I know, but just wanted to bring this to everone's attention. But cost goes up with further mods so I must agree that a certain power and/ or torque level should not be exceeded when tuning a standard or light modified vehicle. |
| Bigger brake master cylinder options | Koen | 10 | 1,709 |
01-08-2026 03:12 PM Last Post: r.ave |
| bigger radiator for AE86? | Uzelac | 3 | 7,621 |
08-14-2015 07:08 PM Last Post: bozu |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 10,166 |
| Bigger injectors | mms | 2 | 4,746 |
01-17-2012 11:47 PM Last Post: gon |
| Need engine,any engine | Apolan | 25 | 25,131 |
10-29-2006 06:55 PM Last Post: ZaX |
