aluminium radiator
05-23-2012, 05:11 PM
aluminium radiator
But the weather show that issue different variously places. And i think not ever put smaller radiator than stock.
05-23-2012, 05:16 PM
aluminium radiator
[Walaki]D`Lair Wrote:
ditn Wrote:Why not go to some local rallyshop or shop
For 60 € you get a double row radiator completely renewed for your old one here.
We dont have those... Sad
No local rallyshops or so?
05-23-2012, 05:40 PM
aluminium radiator
Rally life in Hungary is pretty much f*cked in the last few years, all it is about now is pure money washing... Banging head
05-24-2012, 12:36 AM
aluminium radiator
fax0815 Wrote:For what you want you could either run a normal AE86 alloy rad that sort of fits the genuine mounts, all you have to do is adapt the hoses. Not sure about the outlet diameter on the F20, but the normal Civic runs 30mm i.d. just like the AE86.
Other option, (the worse IMHO) is to buy the s2000 rad and try to adapt it into the AE86, new brackets and stuff, and I bet you´ll still neet custom hoses to suit the AE86 engine bay.
Cooling wise it does make no difference, at all. In fact I´ve seen 2,2l drag EP9 Civics with turbos running the normal very small alloy rad. All you need is a good fan, might cost 100€ for one but its money well spend.
With the Koyo on my Corolla 1,6 16v I wont need to run the fans under normal driving conditions, even under light drifting it hardly reaches the 100°C, if I switch on the fans it immediately cools it down to 85 deg.
The outlets for the 4AGE and the F20C are on the opposite sides of the radiator, and thus I dont want to use long (and ugly) hoses with the AE86 radiator when the F20C will be under the bonnet. The costs are the same for the AE86 and the S2000 rads, dimensionally they are almost the same and custom brackets are no problem for my fabricators Smile
With the OEM AE86 radiator for the blacktop, I had some light overheating when drifting on a slow, twisty track on a VERY hot summer day, even with a SPAL fan...nothing serious, just some bubbling in the reserve tank...
If the S2000 rad bolts almost in it might be the better solution. Smile
You managed to overheat the OEM rad with a spal fan, now imagine a decent alloy radiator with the spal fan... problem solved.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-24-2012, 08:23 AM
aluminium radiator
i did order nice looking rad, lets see how it fit. i let you know..
  Radiator & grill support panel (Levin) FanIsHere 5 4,971 11-14-2022 10:07 PM
  Alu thick core radiator fitment Gtsi-R 5 5,729 01-26-2022 01:28 PM
Last Post: Gtsi-R
  AE86 F20C swap - Radiator issue mad.matt 3 8,283 02-07-2018 05:14 PM
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 8,300 06-23-2017 05:21 PM
Last Post: pack
  cool lower radiator hose thanos 4 7,921 11-29-2016 01:06 PM
Last Post: thanos
