ae86 yellow konis
04-24-2009, 02:17 PM
ae86 yellow konis
Is there any other (easy) way to adjust front ae86 yellow konis with out pulling off and disassembling the whole strut apart?
04-24-2009, 03:09 PM
ae86 yellow konis
By the knob on top of the damper which is accessable when you pop the hood ?
04-24-2009, 03:17 PM
ae86 yellow konis
I dont think so, cause the damper needs to be in the highest position to enable the stiffness adjustment,
or maybe lift up completely the front and rotate the rod by hand... edit: sorry pressed not extended... 280z '75 audi S4 B5 '99 KE25 '71 |
04-24-2009, 03:51 PM
ae86 yellow konis
Uzelac Wrote:??? There is no knob on the top of ae86 konis. The ae92 short stroke version has it. You need to press them completely in order to make adjustment. Fun is not the straight line! |
04-25-2009, 01:27 AM
ae86 yellow konis
I have AE92 ones at the front and they can be easily adjusted, but rear shocks are ofc AE86 model, and there is no easy way, only press and turn.
On the bright side, you need to set them up only once..
04-25-2009, 07:57 PM
ae86 yellow konis
Sorry, my bad, i presumed you are talking about AE92 Konies, aka shortstroke for AE86.
Regards |
| Problems installing yellow koni's in my TE71 liftback | teun | 12 | 19,272 |
11-09-2013 03:01 PM Last Post: teun |
| french (yellow) headlights.... | mirko | 15 | 20,244 |
03-23-2011 09:30 PM Last Post: irish ae86 |
| Cusco adjustable top mounts on Konis problem | speed-inc | 8 | 11,411 |
07-03-2008 10:52 AM Last Post: speed-inc |
| Which Camberplates do fit on Koni Yellow dampers? | AshCampbell | 41 | 45,874 |
07-02-2008 04:28 PM Last Post: AshCampbell |
| What spring rate will suit my Konis? | ts@n@k@s | 1 | 4,195 |
05-02-2008 10:29 PM Last Post: ts@n@k@s |
