06-29-2013, 04:04 AM
Post: #101
if you look at the std factory harmonic balancer you will see rubber in between steel and outer ring
06-29-2013, 10:51 PM
Post: #102
Celica RA45 Wrote:if you look at the std factory harmonic balancer you will see rubber in between steel and outer ring
when did you see a performance motor tuned or race motor with harmonic balancer on the pulley ??
also now the pulley turn only the altenator plus that i put smaller altenator from a yaris .
why also they sell the alloy one for the sxe10?
why also to change the Dual mass flywheel ??
let all the smooth heavy thinks on the motor ..
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-29-2013, 11:15 PM
Post: #103
Today i saw this box in front of me That travel all the way from japan and inside was the beautiful bodykit.
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-30-2013, 08:13 AM
Post: #104
ok these are the 1s that i use .and im reving mine to 9400 rpm with max power at 9200
[Image: AEU86 AE86 - ae86 racecar with beams engine]
and this is the other 1
06-30-2013, 10:09 AM
Post: #105
Not only are harmonic dampers necessary but they are also engine type specific being "tuned" to to the crankshaft.
If the pulley that was removed was a damper type and some are not, then you would be well advised to re-use it after careful checking of the rubber.
Why do you think Toyota put the rubber there in the first place ?
I'm sure if you do an internet search you will find more info on this.
10-14-2013, 10:34 PM
Post: #106
after long time i finaly get the car on the road .
did the first event also .
post some fotos and a video that i found.
The car is great suspension from the MCNSPORT is top .
need more time on the track to setup better the car .
and i need to adjust the engine to get more power at top end.
soon i will post some good fotos and some in car videos .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
10-14-2013, 10:36 PM
Post: #107
http://www.youtube.com/watch?v=oL-2eAMPj...re=mh_lolz
is on practice so i dint have space to test the car lot of drift cars.
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
10-14-2013, 10:39 PM
Post: #108
I just take out the vvti cam gears and put the toda adjustable cam gears .
how much advance or retard in degrees i have to put on the cams to have more power at the top ?
Thanks
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
10-15-2013, 07:27 AM
Post: #109
i dount think just changin cam gears give you any power. beams adjust them LOT.
mayby you want cams, thats why vvti have been taken out many times
06-23-2014, 10:58 AM
Post: #110
https://www.facebook.com/photo.php?v=102...=2&theater
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 54,180 07-22-2019 02:55 PM
Last Post: apardal
  Krullibulls Ae86 BEAMS is the only way krullibull 86 113,785 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 870,594 09-03-2017 09:24 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 701,866 06-27-2017 12:21 PM
Last Post: DJexor
  S.K.s AE86 racecar S.K. 207 268,057 09-18-2016 11:39 AM
Last Post: totta Crolla
