06-26-2013, 11:15 PM
Post: #91
corolla4agze Wrote:i have read that is200 engine mounts are similar but harder.. those not cost lot.
idid drop front axle about 8mm (weld spasers between body/axle)so little more room there aswell.. in weekend i hope i get to put engine on.
By doing this you just lost 8mm of lowering the car .
these effect the geometry.
i dont agry by using spacers .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-27-2013, 12:01 AM
Post: #92
i do have 35mm RCA on front =) so still on big plus.
those spacers help lot on roon in tunnel, and whit turbo the hood is quite close also.
STILL the engines oil pan dount SIT SO LOW.. it sit lower than front axle if you put it rest to axle and no spacers. Now i not need put it laying so low.
06-27-2013, 01:17 AM
Post: #93
corolla4agze Wrote:i do have 35mm RCA on front =) so still on big plus.
i have 45mm rca .if you need to go low you dont want spacers
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-27-2013, 12:45 PM
Post: #94
i would be a bit worried about you new alloy harmonic balancer as this will break your crank on the front
also if you go dry sump i have dry sump pans in stock to suit all 3sge motors in fwd or rwd
06-27-2013, 05:11 PM
Post: #95
Celica RA45 Wrote:i would be a bit worried about you new alloy harmonic balancer as this will break your crank on the front
yes i will need a dry sump later when i will tune up the engine pistons cams etc. Thanks.
can you explain the meaning of this?{ i would be a bit worried about you new alloy harmonic balancer as this will break your crank on the front}
Alloy harmonic balancer ???? why brake the crank ???
Sorry make it more simple my english are not so good .
Thanks
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-27-2013, 06:28 PM
Post: #96
What brand outer tie rods are you using (the purple ones) and how do you like them?
06-27-2013, 11:44 PM
Post: #97
Deuce Cam Wrote:What brand outer tie rods are you using (the purple ones) and how do you like them?
Nagisa auto. Exelent
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-28-2013, 05:05 AM
Post: #98
std harmonic balancer has rubber built into it to take harsh harmonics out of crank
yours is just a lightweight peice of alloy with no crank dampening built into it
06-28-2013, 10:32 AM
Post: #99
Celica RA45 Wrote:std harmonic balancer has rubber built into it to take harsh harmonics out of crank
If you mean the crank shaft pulley the std. was without rubber just a heavy steal one they also sell one alloy here it is http://www.fortyone.co.nz/parts/view/14023.html . i just make one by my self .
other then this i dint change somthing else .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
06-28-2013, 11:25 AM
Post: #100
Great project, keep up the good work Smile
I'm currently taking HRT ~ Hachi Roku Therapy Big Grin
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 50,060 07-22-2019 02:55 PM
Last Post: apardal
  Krullibulls Ae86 BEAMS is the only way krullibull 86 104,065 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 818,300 09-03-2017 09:24 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 668,734 06-27-2017 12:21 PM
Last Post: DJexor
  S.K.s AE86 racecar S.K. 207 252,428 09-18-2016 11:39 AM
Last Post: totta Crolla
