ae86 crush sleeve length
02-20-2014, 12:58 AM
Lengthen your old one, either with a hammer - the peening end of a ball-peen -, or with shim/s.
02-20-2014, 02:02 AM
jondee, you are indeed correct. i reached the rotating torque only around 40 ftlbs. this means I cannot use this old one right? then I have no choice either put shims to the old sleeve, or make a solid spacer and shims
02-21-2014, 12:43 AM
choyr Wrote:jondee, you are indeed correct. i reached the rotating torque only around I hope you realise that you have just forced me to read though a lot of hardcore tech articles to try and figure this one out ![]() really know for sure what causes the crush tube to come loose ?? Basically you need to preload the bearings to keep them happy. The crush tube is essentially there to provide some decent clamping force for the pinion nut, to stop it coming loose and unravelling. Staking the pinion nut is another attempt to keep it from moving. Once installed the crush tube does not see any extra load. In theory, you don't even need it if you could lock the pinion nut after preloading the bearings in some other way... by welding it for example. The radial loads on the pinion gear translate into axial tension loads in the pinion shaft. Sudden loads can produce enough "stretch" to overcome the bearing preload, and then the shaft will snap back elastically. This is effectively a "hammer blow" on the end of the crush tube. When this hammering occurs repeatedly, either the crush tube becomes slightly shorter, or the pinion nut becomes loose and starts to back off, (I'm not sure of the exact mechanism) and the pinion shaft starts to float longitudinally. This is a situation that is commonly referred to in engineering circles, as the point at which everything turns to sh*t. So to answer you question... yes, you could use the old crush tube if you are confident that the pinion nut will stay exactly where it is. I can't remember how much thread you have to work with... maybe Loctite a jam nut on top of the pinion nut, mark it and check it after you have been driving for a while. I would still recommend getting a new crush tube (and new pinion nut) and installing it as soon as you have the opportunity. Cheers... jondee86 |
02-21-2014, 08:10 PM
ae86 crush sleeve length | |||
02-26-2014, 05:03 PM
Rear arm length | totta Crolla | 7 | 2,538 |
06-05-2024 08:53 AM Last Post: totta Crolla |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 7,568 |
Door length | Ivan141 | 3 | 5,718 |
03-18-2014 02:11 PM Last Post: Ivan141 |
Length of factory cat | Rick | 4 | 8,574 |
08-07-2013 06:03 AM Last Post: jondee86 |
Valve springs length | Vil | 4 | 6,638 |
04-04-2013 07:41 PM Last Post: oldeskewltoy |
