about TRD Lsd identification
05-17-2010, 11:50 PM
I need help to know the LSD Type shown on pics
I know it's a TRD But what type : 1 way , 2 way .....? Thanks for helping Phil Filh Save the RWD cars |
05-18-2010, 01:30 AM
2 way for sure
![]() It is really late for me, so I will explain in French, sorry for people who don't understand french... regarde sur ta 2nd photo, les 2 pièces en haut. l'endroit ou se positionne les axes de satellites (les petit pignon) sont en V parfaitment symétrique donc 2 voies ![]() si c'était 1 voie tu n'aurai un demi V ( |/ au lieu de \/) et un 1.5 voie tu aurai un V non symétrique (un coté plus prononcé que l'autre) |
05-18-2010, 02:34 AM
ça c'est de l'explication , grand merci à toi .
thanks to you ProjectD phil Filh Save the RWD cars |
05-18-2010, 09:42 AM
Does TRD have anything other than 2way ?
I think not. |
05-18-2010, 10:32 AM
They sure do..1.5 way also.
This is a two way..you can see the two diamond shape ramps (ramp angles) on both diff halves. They are exactly the same, hence two way. I guess projectD said something along the same lines. You can see them in the second pic. The two thingies at the top. A wheel to steer the front of the car A pedal to steer the rear |
05-18-2010, 11:22 AM
You're right, just checked:
Zenki 2way 41301-TA005 Zenki 1.5way 41301-TA006 Kouki 2way 41301-AE804 Kouki 1.5way 41301-AE805 |
05-18-2010, 11:39 PM
I also noticed a T2 mark on cover , guess it's the abreviation for Two way .
I think I know what I need to buy . I broke a half shaft (it's the fifth one) due to rallye use .... And when cleaning gear end I found that LSD is cracked on the just under cover plate . The TRD LSD is very reliable , I used it for many years in rally, without any problems, I'll try to find an used one , on Ebay . If you have good links , don't hesitate . Phil Filh Save the RWD cars |
05-19-2010, 08:13 AM
Yes Nohachi that exactly what I said, but in french
Filth, If you don't whant to break half shaft anymore see the oversized one made by weir performance. :wink: |
05-21-2010, 01:15 AM
Yes I saw the big half shaft , but I'm not sure it's the solution for me . Ionly have 135hp, but it's the way I drive in rally that lead to the half shaft explosion....
| LSD identification | FanIsHere | 4 | 3,297 |
11-25-2024 11:58 AM Last Post: FanIsHere |
| Valves identification | FanIsHere | 1 | 4,553 |
10-29-2020 06:18 PM Last Post: oldeskewltoy |
| Brake calipers identification | FanIsHere | 4 | 6,792 |
10-23-2020 11:45 PM Last Post: FanIsHere |
| Piston Identification | Alex170984 | 3 | 7,345 |
05-17-2016 12:47 PM Last Post: Alex170984 |
| Removing unnecessary wires.. some identification help! | 4000GT | 3 | 6,738 |
08-20-2011 04:40 AM Last Post: 4000GT |
