Which engine/tranny mounts???
07-30-2008, 01:00 PM
Does anyone have experience with different kinds of these mounts?
Mine are worn out so I need new ones.
Robokill tried the Cusco ones, they are alot stiffer than standard items, which is nice.
But there is also a drawback, they send massive vibrations through the car, I know this is inherent to stiffer materials but I want something in between the standard and Cusco ones.
Are the TRD mounts a solution perhaps?
Any info and experiences are welcom. Thumbs up!
Aram.
08-01-2008, 07:10 PM
cusco lowers the engine and gearbox a little, which is good for your center of gravity. Stock mounts shoulc do fine, but if the car is used for track, then vibrations are not a big concern.
08-02-2008, 10:50 AM
revolver and also techno spirit pro do similar items
08-05-2008, 01:28 PM
Quote:cusco lowers the engine and gearbox a little, which is good for your center of gravity. Stock mounts shoulc do fine, but if the car is used for track, then vibrations are not a big concern.
Very marginal though - side by side maybe 2/3 mm between them - cant see it making any difference?
[Image: AEU86 AE86 - Which engine/tranny mounts???]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
08-05-2008, 04:21 PM
havent seen the actual items myself.. it is a lot of weight so lower is always better. But I doubt you'd notice 2-3mm indeed.
08-05-2008, 07:22 PM
Techno pro spririt = 10mm lower
08-12-2008, 06:03 AM
The TRD mounts are the ones to get because stock or generic replacements costs just as much and are not as hard, durometer.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  20v BT - which oil pump? Mylesmck 4 6,204 06-21-2022 04:51 PM
Last Post: pack
  Lets talk engine mounts kazi 6 11,346 08-31-2017 12:46 PM
Last Post: parrot
  Rim width. Which is best.... Dino86 5 10,230 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 11,626 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 7,359 02-15-2015 11:14 AM
Last Post: ditn
