Where to find the informations on the gearbox/engine
02-07-2009, 11:02 PM
If you ask me that does not look like a T series at all: not square and its got only two ribs.
It looks like the W55/58/59 which does only have two ribs: http://www.customtacos.com/forum/showthr...p?t=121942 I know Toyota installed some W59s in trucks, so perhaps that's where the gearbox came from. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
02-07-2009, 11:06 PM
thanks for the precision.
The engine on it is a diesel, 2C. So if i swap, i have to find a gearbox also ![]() |
02-07-2009, 11:30 PM
Not entirely true: a W55/56/57/58/59 gearbox should be compatible in its bellhousings, so if you want to drop in a 4AGE you can buy a 4A->W58 bellhousing and swap that for the 1C/2C bellhousing on your W59.
There are several sources for that bellhousing, but most of them are unfortunately located in Australia: http://www.ajps.com.au/parts/w5x_bellhousing.asp 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
02-07-2009, 11:34 PM
banpei Wrote:Not entirely true: a W55/56/57/58/59 gearbox should be compatible in its bellhousings, so if you want to drop in a 4AGE you can buy a 4A->W58 bellhousing and swap that for the 1C/2C bellhousing on your W59. you lost me on the way ![]() ![]() ![]() i am used to Toyota logic yet. Honda is more simple ![]() i am planning more on a 3SGTE, but a 4A can be good to start ![]() |
02-08-2009, 10:33 PM
Well, it isn't entirely Toyota logic since Toyota isn't the manufacturer of those boxes. But basically what happens is that the gearbox is a loose component and the engine needs to be fitted to that. That's why there are different bellhousings which fit on certain gearboxes.
In case of the W series there are two generations of W gearboxes. The new series start at W55 and the bellhousings are not compatible with older series. As stated before: the 3S fits on the 1C bellhousing. If you currently have a 2C engine fitting on the W59 gearbox it should fit the 3S engine since the 2C should have the same block as the 1C. I also see several resource around the world saying the 1C and 2C both fit. Personally I would go for the 3SGTE. If you would put a 4AGE in there you only would be disappointed in the amount of time, money and effort you put into it and having less torque than the 2C diesel had. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
02-12-2009, 06:26 PM
banpei
Thanks for your reply ![]() I have to find out if the gearbox is really what it seams. For the moment, the only engine i found in Malta is a 3SFE which might be the first step to go, or i will go for a complete MR2 in UK for swap. Do you know if maybe some parts of the MR2 (chassis) would fit the TE ? What is strange for me, it is not to find some special engine mount done especially for swap, like there are for Honda ![]() |
04-10-2009, 07:49 PM
Hi
I took off this bloody gearbox and i cannot find the number on it. I do not know what gearbox it is ![]() |
Emergency help find store with bearings france | Allexz | 5 | 5,577 |
09-12-2019 03:24 PM Last Post: Allexz |
ford type 9 gearbox with 4age engine | filh | 29 | 53,316 |
01-11-2015 01:02 PM Last Post: filh |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 9,032 |
Were to find 4AG-ZE gaskets in toyota diy? | fax0815 | 17 | 17,893 |
05-28-2013 10:17 PM Last Post: ditn |
Question: Where I can find this fender flare? | winchi.c | 3 | 5,721 |
05-01-2011 09:58 AM Last Post: Bentley |
