Where to find the informations on the gearbox/engine
01-26-2009, 08:14 PM
Hi.
My TE71 was swapped with a Toyota Diesel engine ![]() So tomorrow i am going around to check what there is. But where can i find for example T50 on the gearbox, or 2 TC 3 TC Sorry to ask but i am more on Honda stuff (which i know where to look at for the info). And how to recognize the steerings "Worm and Roller" and "rack and pinions" Thank you ![]() |
01-26-2009, 08:37 PM
Diesel!
![]() Then the engine should most probably be a 1C... T50 should be readable on top of the gearbox... You can see here how the T50 and K50 (just in case) should look: http://www.aeu86.org/viewtopic/ae86/p/96200#96200 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
01-26-2009, 08:42 PM
banpei Wrote:Diesel! Yes ![]() 1C ? ok if you say so ![]() i will put some updates on my TE71 topic with photos. I went to a guy, he had 2C engine (diesel) or something like that, and i checked the gearbox i couldn't find anything ![]() thanks for the link ![]() |
01-26-2009, 08:45 PM
If you have a 1C engine it is probably mated with a W51 gearbox a 3SGE swap would be a good substitute for the 4AGE. >
01-26-2009, 08:50 PM
banpei Wrote:If you have a 1C engine it is probably mated with a W51 gearbox a 3SGE swap would be a good substitute for the 4AGE. > you are speaking for me for the moment ![]() ![]() so W51 will suit a 3SGE ? What engine is that ? (i am going on wiki) |
01-26-2009, 08:53 PM
ouhhh yaeeaaahh 2.0 liter of the MR2, some VVTI, some Lexus.
Perfect for me ![]() i have to find out what gearbox i have to be sure but has it is on top, i cannot check ?! |
01-27-2009, 06:18 PM
I checked it is a 2C engine.
I found a 3SFE at the scrapyard. Can it fit ? Thanks (i am fed up diesel ![]() |
02-06-2009, 01:20 PM
The T50 gearbox does not have "T50" or anything like that written on it. You can identify the T50 gearbox as it is a split case design, which is sort of rare.
A W series gearbox is a more regular sandwich style gearbox. |
02-06-2009, 01:22 PM
Jonny Rochester Wrote:The T50 gearbox does not have "T50" or anything like that written on it. You can identify the T50 gearbox as it is a split case design, which is sort of rare. Thanks. I try to do a photo of it today, so you tell me as i cannot find out ![]() |
02-07-2009, 01:15 PM
![]() ![]() doubt you can see something but... ![]() |
Emergency help find store with bearings france | Allexz | 5 | 5,490 |
09-12-2019 03:24 PM Last Post: Allexz |
ford type 9 gearbox with 4age engine | filh | 29 | 52,842 |
01-11-2015 01:02 PM Last Post: filh |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,943 |
Were to find 4AG-ZE gaskets in toyota diy? | fax0815 | 17 | 17,690 |
05-28-2013 10:17 PM Last Post: ditn |
Question: Where I can find this fender flare? | winchi.c | 3 | 5,667 |
05-01-2011 09:58 AM Last Post: Bentley |
