Whats the biggest cams for the 4AG?
04-14-2005, 01:59 PM
Sounds good to me ...why don't we start our own championship?
AE86 FANATIC!!! |
04-14-2005, 02:03 PM
Mmmmh, guys, offtopic !
Lets use this thread for big cams, ok ? Pesonally if any modification is prohibited - I will stop under 270 cam. Maybe 264 (If I remember correctly). If the engine is lambda-sensored, the ECU can manage up to 10% corrections - I think. |
04-17-2005, 02:49 PM
the 16v 4AGE isn't lamda sensored right. So How much can the MAP ECU correct. I know that if the engine is MAF then its like 10%
You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
04-18-2005, 02:09 PM
Mulisha, some 16V 4AGE's are not lambda sensored.
Some are. Even on AE86. |
04-18-2005, 02:41 PM
Weird, Why cant they make the engines all the same.
So 270 is the max that an ECU can handle it I have the 16v with MAP and no Lambda You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
04-20-2005, 12:42 PM
Had a set of cams in my hand the other day with an 11mm lift!!!!!!! animals
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 3,075 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 17,149 |
| Shim size for AM cams | kazi | 4 | 7,337 |
| whats the crack with 16v turbo? | kazi | 5 | 8,581 |
08-02-2017 12:15 AM Last Post: kazi |
| Toda Cams | Alex170984 | 7 | 11,298 |
02-11-2017 05:50 PM Last Post: Alex170984 |
