What ride height for ae86 lower springs at the front???
09-06-2007, 12:33 PM
Hi peeps.
I have a KE70 Estate.
I found a company here in the UK that will take ths STD ride height front springs and heat and change the spring rate and ride heigh of them for a small fee.
Now, to me, this is a better way to lower it than chopping the springs but the problem is....
How much should I get the springs reduced to??
40mm ??
60mm ??
80mm ??
I want the car quite low to be honest but I dont want it lower than it need to be.
What do you people run??
Cheers
Adam Smile
1980 Toyota Corolla KE70 DX
1983 Levin GTV
[Image: AEU86 AE86 - What ride height for ae86 l...e front???]
09-08-2007, 01:55 AM
Measure how much travel is in the front suspension now; from where
it sits until it touches the bumpstops. You need about 70 mm to keep a
reasonable amount of suspension travel with standard rate springs.
If you have more than 70 mm, the difference is how much you can
lower the front.
Cheers... jondee86
  HKS valve springs totta Crolla 3 4,255 05-25-2022 10:24 PM
  cool lower radiator hose thanos 4 7,633 11-29-2016 01:06 PM
Last Post: thanos
  Springs from other vehicles?? FanIsHere 16 19,643 05-17-2016 09:12 AM
Last Post: FanIsHere
  Lower arm hits toe arm on lock... fullybuiltmiata 12 17,951 01-14-2016 11:52 PM
Last Post: Deuce Cam
  3rd door support gas springs (stay) - worn out max_ae86 5 8,035 09-01-2013 03:20 PM
Last Post: Jezza_hr
