What is this wire for?
07-06-2008, 03:55 AM
Does anyone know if I need this wire conected?
http://i292.photobucket.com/albums/mm6/j...ure190.jpg http://i292.photobucket.com/albums/mm6/j...ure191.jpg Thanks, Jason |
07-06-2008, 06:01 AM
hmmmmmmmmmmm not as familiar with SOHC... but I believe that is just for the gauge.... you'll have no idea how warm, if warm, when warm your engine is... but I don't believe it has a function other then the gauge
Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-06-2008, 08:38 AM
Yup... sure looks like a temp sensor connector... probably fell off
that water temp sensor (brass hex thing) in behind. Cheers... jondee86 |
07-06-2008, 09:27 AM
This is a conector for the watertemp in front of the engine. And it does excists on the soch! cuz i use the same harness from the soch to my doch..
![]() Don“t Think About The Past, Live In The Present And Dream About Tomorrow |
Tachometer wire colour | Jezza_hr | 8 | 15,704 |
10-13-2013 03:52 PM Last Post: parrot |
MSD 8980 setup - which wire does the dizzy connect to? | megabob | 8 | 18,571 |
11-22-2011 07:02 PM Last Post: Project D |
Speedo wire on dash? | 4000GT | 1 | 3,798 |
05-24-2010 10:14 AM Last Post: 4000GT |
tacho signal wire | totta Crolla | 7 | 14,859 |
04-12-2010 09:44 PM Last Post: Okami |
What wire brings power from the battery to the radio? | Rasteirinho | 7 | 9,272 |
11-11-2008 11:53 PM Last Post: mirageR |
