What is this part...
06-29-2014, 10:10 AM
(06-28-2014 09:18 AM)Bean Bandit Wrote:  Seriously just go down to your local store and buy what ever they have in mid price range and around 60amp (45minimum).
No need for a Braille unless you're taking part in very serious racing competitions or money is no issue because you earn/got more than plenty of it.
Sent from my Nexus 4 using Tapatalk
Just installed a new battery.
Always the same. Doesn't start. :-(:-(
I turned the cranck whith a wrench to help the starter to engage the flywheel and sometime by chance it start.
My alternator is in good condition.
So, i guess the problem come from my starter ?
What you think ?
From which car come this 1G series from ?
Envoyé depuis mon GT-I9100 avec Tapatalk
06-29-2014, 01:08 PM
Bad ground connections would be the next thing to check... Results in similar problems as a bad battery.
06-29-2014, 03:52 PM
(06-29-2014 01:08 PM)Ivan141 Wrote:  Bad ground connections would be the next thing to check... Results in similar problems as a bad battery.
There is a ground connection at the gearbox and the engine. Isn't it ?
07-05-2014, 07:05 PM
New battery, Alternator OK, New starter, Ground Wiring OK.
Car won't start when cold. WTF......
Please help :-( :-( :-(
07-06-2014, 04:57 PM
(07-05-2014 07:05 PM)izanagi Wrote:  New battery, Alternator OK, New starter, Ground Wiring OK.
Mine had hard times cranking especially when hot (turned maybe 1rev/sec). I made a direct ground cable from the gearbox to the ground of the battery... problem solved.
07-06-2014, 06:49 PM
Ok. Some news.
The "click" noise that i was hearing come from the circuit open relay and now the start pinion hitting the flywheel.
I will replace the relay and see what it happen.
