What is the cylinder head x engine block torque specifcation
11-11-2007, 10:23 PM
Hello,
I need to know what is the torque specification for the bolts from cylinder head x engine block.
I think it's 30 N.m more 90º and more 90º...
Keeping the AE86 alive!
11-11-2007, 11:22 PM
removed wrong values
It's on page EM-117 of my 4AGE manual, but perhaps you can find it here as well:
http://files.aeu86.org/manuals/4A-GEManual.pdf
[Image: AEU86 AE86 - What is the cylinder head x...ecifcation]
11-11-2007, 11:57 PM
That's strange banpei...
I have a RM from the 4AFE and 4AGE engine (for the Celica, Carina and Corolla i think) and it says that the torque is 30 N.m, then 90º and then another 90º.
Very strange i think...
I ask because my engine is loosing water between the cylinder head and engine block immediately after start.
11-12-2007, 01:06 AM
AE86 engine bay stickers
300kg +90/+90 or see manual!!!! which tells you something else
11-12-2007, 01:55 AM
2 figures...
I supose they are equivalent...
11-12-2007, 06:03 PM
Ah, I see my error... Banging head
Looked at the wrong head: info I gave you are for the 8-valve head.
Correct value would be 300kg/cm (22 ft/lb, 29 N.m) if you look at page EM-117 in the manual.
11-13-2007, 11:47 PM
OR... if you have an olde manual you will note the head to block torque is 44#s. Btw... the head bolts NEVER changed part numbers... so new ones are not TTY. I used 44#s when I built my engine 5 years ago.... no head gasket or overheating issues.
I believe.... the new spec is cause there were too many STUPID techs who didn't think to do the head bolts in 3 passes(25, 35, 44). The new spec pretty much requires them to do it in 3 passes..........
Dan -
11-14-2007, 11:21 AM
Well, but it's tough to make the 3rd pass (last 90º).
  Bigger brake master cylinder options Koen Bongers 3 191 11-25-2025 09:05 AM
  4AGE cylinder head plug removal Ivan141 5 3,776 09-30-2023 09:47 PM
  Question about 4AG 20v Engine Block CHACAMAN 1 2,559 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  4AGE block differences explained (incl. some eyecandy) Bean 46 99,336 05-05-2019 04:03 AM
Last Post: Rocker100
  BT head with ST block. CHOPKIN2 6 8,831 02-06-2018 06:27 PM
