What is good oil pressure?
05-28-2011, 01:06 PM
Im only after rebuilding my 4age, it got
all new ACL bearings bottom end
TRD HeadGasket
Toda cams
Vernier adjustable pulleys
Lightweight flywheel
As far as I remember on my standard gauge the cam never moved much from 3/4 oil pressure at all times.
Now after the rebuild it is sitting at just over half way at idle and always above 3/4 when being drive sometimes even close to the H mark.
Is the low pressure at idle normal, im just worried as im not used to it!
Thanks
05-28-2011, 01:59 PM
sounds perfect to me mate! Thumbs up! thats where it should be! 1/2 or just left for Idle, and 3/4 for Driving :wink:
05-28-2011, 07:18 PM
About half idleling is perfect. More than 3/4 sounds like you have a pressure valve that doesn't open... Are you running stock oil cooler setup?
[Image: AEU86 AE86 - What is good oil pressure?]
05-29-2011, 12:47 PM
i always have pressure at 3/4....why??
05-29-2011, 01:02 PM
gauges and sensors can be faulty too, and not accurate!
05-29-2011, 03:30 PM
Petros AE86 Wrote:i always have pressure at 3/4....why??
Mine used to be like that ive used a diffrent fuel sender after the rebuild so I think the old one was possibly faulty
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 1,769 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 23,150 08-19-2018 12:08 PM
Last Post: AlexKTM
  D2 Coilovers any good? heshan 18 29,335 04-04-2017 02:40 AM
Last Post: hachirokkos
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 5,702 11-05-2016 01:34 AM
Last Post: oldeskewltoy
  Oil Pressure Query Alex170984 2 5,785 12-11-2014 01:25 AM
Last Post: Alex170984
