What engine
11-13-2010, 03:57 PM
What engine
Ive done a bit of research into the toyota 4age engine but still not 100% on what engine I have. cant really get a good look at the side of the block to see if its 3 or 7 ribs on it.
I take it that its large port? Heres some pics ![]()
11-13-2010, 07:29 PM
What engine
hmmmmmm, can't really tell what block you have from this angle... but I am sure you have a TVIS engine, and if it hasn't been taken apart, or opened up before, it is likely to have 10 to 1 pistons instead of 9.4 to 1. I'm making that guess based on the T/B vacuum connections, and your engines lack of other vacuum parts.
11-13-2010, 07:41 PM
What engine
oldeskewltoy Wrote:hmmmmmm, can't really tell what block you have from this angle... but I am sure you have a TVIS engine, and if it hasn't been taken apart, or opened up before, it is likely to have 10 to 1 pistons instead of 9.4 to 1. I'm making that guess based on the T/B vacuum connections, and your engines lack of other vacuum parts. very simple all non afm models in EU are running the 10:1 comp pistons. Big port head and if its 3 or 7 ribs doesn't really matter there is a 99% chance you have a 40mm crank with 18 mm piston pins. There is a not a valve cover that changes that
12-02-2010, 09:07 AM
What engine
mms Wrote:Ive done a bit of research into the toyota 4age used engines but still not 100% on what engine I have. cant really get a good look at the side of the block to see if its 3 or 7 ribs on it. I am just wondering if this is just an ordinary engine or having good quality of engine. Let me know.
12-02-2010, 11:34 AM
What engine
ordinary
12-02-2010, 12:34 PM
What engine
Who knows what's inside.
I aint stock, at least exhaust header isn't. |
12-02-2010, 01:32 PM
What engine
Note the oil drain to the rear of the head.
This indicates late model block. Likely high comp pistons, 7rib, 42mm crank. ![]() No oil drain (low comp block, likely 3rib, 40mm crank) ![]() Note that there are many intermediate versions. 7rib low comp blocks etc. Lots of info here. Oil drain is easiest to see to determine block type. http://www.club4ag.com/faq_and_tech_page...0Block.htm |
12-02-2010, 01:37 PM
What engine
Where can you see the oil drain on those pictures? I just cant find them
12-02-2010, 05:19 PM
What engine
12-02-2010, 05:56 PM
What engine
i see there is a map sensor on the firewal
so i think it is an 10 to 1 comp. engine with T-vis. 3 rib or 7 rib.. '87 levin coupé |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 11,202 |
| Need engine,any engine | Apolan | 25 | 28,922 |
10-29-2006 06:55 PM Last Post: ZaX |
![AEU86 AE86 - What engine [Image: AEU86 AE86 - What engine]](http://i5.photobucket.com/albums/y196/minimanshane/IMG_0176.jpg)
![AEU86 AE86 - What engine [Image: AEU86 AE86 - What engine]](http://skynet.ie/~eireae86/tech/engine%20buildup/41%20install%20SC%20bracket.jpg)
![AEU86 AE86 - What engine [Image: AEU86 AE86 - What engine]](http://farm1.static.flickr.com/130/317533952_6bf74b61d3_z.jpg)
