What brakes are you using ?
06-25-2005, 12:06 PM
Pictures of the EG6 kit, 25,000 Yen
06-27-2005, 12:56 PM
I have just ordered a set of Mintex 1155,
Have any of You tried this? regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
06-27-2005, 02:13 PM
Skassa,
Whats the difference between 1144 and 1155? Or is that a type? How much where they and where did you order them? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
06-27-2005, 02:22 PM
1144 is designed for road,light race
1155 is designed for rally trackdays. not good when cold 1166 is designed for pure race and will not work cold I hope i can use them as a everyday pad,but i will see,it was just if others had tried them ,and had some comments to them. I ordered them here in Denmark at a local grosist,and the price is around 70euro Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
06-27-2005, 02:35 PM
Not to bad..
I am thinking of getting 1144s but not sure where I should order them... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
06-27-2005, 05:44 PM
I just want some, that doesnt squeek and squirl... Its really annoying
Any suggestions? I need som new pads for the front pretty soon, as a MOT is in the near future Youtube Myspace and I´ll Google your Yahoo |
06-27-2005, 06:22 PM
Use coppergrease on the back of the pads...I havent heard my brakes squeel in a long time myself..
07-22-2005, 09:53 AM
Do any of you know how wide a disc,that can be used with the OE caliper?
There are some c-class disc ,that are 285x22.and they are easy to redrill,becourse the MB holes are drilled on a 105mm pcd And i wonder if it can fit the 22mm instead of the 18mm ,is there room for it? Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
07-22-2005, 10:00 AM
Denmark Wrote:Do any of you know how wide a disc,that can be used with the OE caliper? AFAIK you could use AE92 front disc with stock AE86 caliper (238mm). Measure the central hole of your c-class discs - if the hole is over ~65mm - they are not applicable (you must redrill them to 4X85 PCD and 12mm holes for studs will be very close to the central hole - that's why I fail using BMW 728i discs). |
07-22-2005, 10:16 AM
the hole in the c-class discs are 67mm.Yes it will be close ,but there are no force in that direction,so i don´t think it will be a problem
I wan´t to have the discs bigger for better cooling,that´s why i wount use the AE92 discs Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
| Rear brakes overheating | Blaze0010 | 3 | 1,342 |
10-03-2025 05:57 PM Last Post: banpei |
| Rear brakes | totta Crolla | 0 | 1,988 |
02-03-2023 12:54 PM Last Post: totta Crolla |
| Switching diffs for disc brakes? | trippin | 6 | 5,664 |
07-08-2022 03:35 AM Last Post: trippin |
| What suspension set up are people using? | kazi | 8 | 11,194 |
07-06-2017 05:26 AM Last Post: headrush |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 5,042 |
