Welding equipment
10-08-2006, 07:27 PM
Welding equipment
Guys,
I've had a good look at the rear of my car, and the general state of my old dapper-crapper volvo 360 and it seems to me that it would be wise for me to learn how to weld. There have been more times than I can remember when I've wished I had a welder at home to do this or that, and now I want to buy one.
But what to buy?
I'm led to believe that a MIG welder would be best for all-round work and ease of use.. and they say to get one with separate gas tank (not the gas-filled wire type).
Can anyone with experience give me some tips on what to look for?
How much amps, what wire thicknesses for car bodywork etc. etc.
Cheers..
10-09-2006, 12:18 PM
Welding equipment
http://business.search.ebay.com/_Busines...QQsbrsrtZd
Choose wise !
I think plasma cutter + welder will be good combo (maybe combined in one single machine).
My choice is:
http://cgi.ebay.com/MTC160-inverter-ARC-...dZViewItem
OR if you want also aluminium welding capability:
http://cgi.ebay.com/welder-super-160-MMA...dZViewItem
It's good to have at least 120Amps (over 160 is overkill), 0.8mm wire (cheap consumable compared to 0.6 one), 1.2mm will be overkill.
10-09-2006, 05:09 PM
Welding equipment
hmm...I'm not too sure about the chinese stuff. Dont exactly have a good reputation quality-wise. BTW, does that thing handle MIG-style welding as well? I think TIG might be a bit too stiff of a learning curve for me.
A 130+ amp 0.6-0.8mm MIG welder is easy enough to find over here for around 400 euro's new, but if that chinese thing can handle MIG/TIG/Plasma cutting it might be worth some consideration.
10-09-2006, 06:16 PM
Welding equipment
In fact in the near past AEG sold large quantity of electrical hand powertools (drills, grinders) made in Bulgaria (and rebadged). I worked in the plant at this time Wave
I bet that almost all relatively cheap stuff is Chinese under "reputable" labels ...
10-09-2006, 06:20 PM
Welding equipment
I know..same story in the electronics business.. almost all home-use devices (dvd players etc) are made in china, but the big brands do keep a tighter quality control than the manufacturers there usually do.
Anyways...I think it's going to end up being a mig welder bought locally. Now just need to find one second hand or just pick one to buy new.
10-10-2006, 10:35 AM
Welding equipment
i was considering that purchase for a long time, almost the same time as i bought my rolla, som 6 months ago, cause it dould be a really less money costly to kame/learn it yourself...but i also can't make my mind what to buy...i was thinking of a MIG/TIG/CUT device...sooo tempting!!
Smile
my rolla's rear end in the boot, where the shox are bolted to the body is really really in bad shape, so i still think of it!!
adam
10-10-2006, 11:25 AM
Welding equipment
have got the same problem as adomz, so I'm looking for a weldingmachine to, Ivan do keep in mind that it can be used with 220V unless you got a 380V circuit to.
and make sure when you buy it it includes everything youu need (machine,gasbottle, wire) cause sometimes they are sold seperatly.
I'm looking for a used one, so if anyone knowes someone please let me know, doesn't have to be TIG it's just to fill up the holes in the car Thumbs up!
10-10-2006, 12:47 PM
Welding equipment
yeah.,..poor car...Smile
will see what i'll get here...asked some peeps over here to see if they can offer me something like that with 3 tips...would be great to learn welding!
adam
10-10-2006, 05:10 PM
Welding equipment
Nice to know I'm not the only one.. BTW, I know most of the time the stuff sells separately.. the gas bottle's are really damn expensive. I can buy a new MIG welder set with everything I need for around 500 euro's.. and be sure that it will do fine for car repair..maybe it would be wise to find a co-sponsor.
10-10-2006, 07:11 PM
Welding equipment
I got a mig from "deca" 130 amp for 0.8 a 1 mm wire it works fine for 0.5mm/3mm.and for the ticker stuf i use "elektrode laspost"(dont know the englisch word?)
  welding the diff, who's done it? megabob 8 10,201 11-26-2010 06:19 PM
Last Post: senna
  Spot welding vs seam welding ---> chassi cannabolic 8 13,328 11-26-2009 01:48 PM
Last Post: HybriD07
  spot welding cannabolic 6 8,671 03-23-2009 11:00 PM
Last Post: brownington_bomber
  Welding chassis (firewall to rail) should car be on stands? eightsixboy 1 4,545 03-21-2007 02:38 AM
Last Post: eightsixboy
  Seam welding, a few questions Morten 3 6,247 12-27-2006 09:56 PM
Last Post: Denmark
