Webber DCOE 45mm for 200hp
05-18-2013, 02:07 AM
oldeskewltoy Wrote:$5000 NZ dollarskpretro84 Wrote:As subject states guys these are the carbs i bout with a smallport manifold. off a running engine so they re a bolt on ready to start already jetted for 4age motor. |
05-18-2013, 02:09 AM
ditn Wrote:for a bit of discussion over the N/A ecu? webbers are way better and no Rev Limit till fuel runs out? |
05-18-2013, 02:12 AM
robokill Wrote:kpretro, if you want a nice engine with no high cost you need the following: This is good the head stuff your saying got more to this? no need to clean motor is new hasnt Run in yet. and is a rebuild. |
05-18-2013, 02:15 AM
einneb Wrote:I think it would be a good idea to do some months/years research before you even start building a 200hp 4a-ge.Love the noise!! Okay guys its now 160 - 185hp? not 200hp |
05-18-2013, 02:32 AM
rene Wrote:if you have no expense with engine building Alright then guys i did read somewhere 45mm webbers are fairly too big for N/A suppose to be 40mm if i was just to swap from efi to carbs 45mm are for some after market cams and modifying things it says. 45mm maybe too big to tune so any suggestion for what type of cams i should get to suit webbers 45mm? ill stick with 160hp then? so ill throw in some after market valve springs and cams and juts rev the shit out of it see what i get? i dont know much about cams so which ones should i go for guys thanks |
05-18-2013, 02:36 AM
so Yeah lets start again guys its now 160 or 170ish hp ignore the 200hp please. ive already got a 300hp 4agte Ke70 its fairly scary to drive so i prob dont need 200hp Starlet. So how about that guys its now lower?
05-18-2013, 02:46 AM
Also i just had a read again on Bills page on the 160hp mark doesnt say much on carbs sadly Just this A quick note - the 4AGE that I have in my AE-86 Sprinter has 288° cams, an aftermarket computer, 10.5:1 compression, and a small amount of head work done. It makes about 160hp with a completely stock bottom end. It ran to 8,500rpm without any problems.
05-18-2013, 09:18 AM
better plan
![]() tbh you dont need 200 hp,160/170 is a very nice number and what most rallydrivers here have. Can i ask why you are so focused on carbs? you could go for a nice itb setup to I think a rallyshop over her sells the ecu+itb and stuff for 1250€ thats cheap. |
05-18-2013, 11:03 AM
Everything you need is in this thread for 160hp:
http://www.aeu86.org/viewtopic/tuned-4ag...4age+power Results were mostly achieved on standard injection so your Weber carbs might even give you a little bit more. Why do you want it to be so LOUD ? An analogue brain in a digital World |
05-18-2013, 12:04 PM
Nice, a 7 double post
Can anyone please explain me, why the hell you want backfires? http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
