WILDER CAMS SETTINGS????
07-26-2005, 01:09 PM
Any progress alimonos? Interested in this as well...
07-27-2005, 10:31 PM
Still truing to make some "proper" setings with the APEXI SAF-C...
When i'm ready i'll write everything here! AE86 FANATIC!!! |
07-28-2005, 08:42 AM
My advice to you: get a wideband O2 sensor setup with display (zeitronics for example). That way you'll be able to monitor what your doing to your mixture under all circumstances. It would be even better to combine this with a programmable management so you could run alpha-N (TPS sensor controlled), but since you have the Apexi you might as well try and make things work with that.
Does anyone have any info on vacuum buffering canisters? I think Ian has one under his bonnet, and it might help alimonos get rid of some idle problems. FABRICA MI DIEM, PVNC! |
07-28-2005, 01:30 PM
What trick is that? AE86 FANATIC!!! |
07-28-2005, 01:33 PM
Ususally that is used if you run quad throttles to even out the vacuum created by those in order to be able to use a map sensor... afaik
07-28-2005, 02:23 PM
Good point, it only creates a single equalised vacuum signal for 4 different connections. Too bad...need to think of something else then.
| Shim size for AM cams | kazi | 4 | 8,111 |
| Torque settings | kazi | 4 | 11,187 |
03-28-2017 12:15 AM Last Post: kazi |
| Toda Cams | Alex170984 | 7 | 12,384 |
02-11-2017 05:50 PM Last Post: Alex170984 |
| 20V cams - CATCAMS vs KELFORD? | Grant | 19 | 48,249 |
11-19-2015 07:45 AM Last Post: hachirokkos |
| cams cams cams | megabob | 60 | 78,767 |
12-31-2013 01:19 AM Last Post: gze spec |
