WILDER CAMS SETTINGS????
07-10-2005, 10:11 AM
Tried to send Ivan141 a pm instead? Dumb question
[Image: AEU86 AE86 - WILDER CAMS SETTINGS????]
07-10-2005, 01:23 PM
The idle air adjusting screw is a small black thingy on the front left strut tower. (behind the fusebox). You can take out the rubber cap and find a screw underneath. I dont know if it will help you out but it's worth a shot.
If none of that helps you can also adjust the throttle cable to stay opened a little, but that is a bit sloppy.
07-10-2005, 09:15 PM
I tried the idle air adjusting screw already. It's the small black thing we use to adjust the CO emissions right?
I tried that but no use...
If i play with throttle cable isn't that going to make a problem to the TPS?
Anybody knows about settings in APEXi SAFC-II?
The type of sensor for us is "pressure" and then we put the value "03" in both IN and OUT settings?
If i set -45% in LO-THROTTLE @ 1000RPM the engine is more functional between 1500-3500rpm. How about the other settings for HI_THROTTLE @ various rpms?
07-10-2005, 10:01 PM
I cant help you with that, dont know anything about the apexi.
I have been reading the experiences of the previous owner of your kamikazee cams, he had the exact same problems. I suggest you contact the supplier and ask if they can give you some advice (ted's components in canada).
262 cams really arent that extreme, so there must be a way to get them working in your setup. Another option that I would certainly try is to send Bill Sherwood a PM, he has done about everything you can imagine to 4a-ge's so he might be able to help out.
07-10-2005, 10:10 PM
I think knudsen was playing around with an apexi awhile back.. maybe he has any idea?
07-10-2005, 11:38 PM
alimonos
have you got the instructions for the apexi, i can email an english copy if it will help. Its just alters the fuelling though, not likey to be the root of the problem, that will be the cams.
Interested what you find though, i have a 264 8.1 waiting for my car and a apexi to help get the fuelling right.
07-11-2005, 12:10 AM
Bill Sherwood is in this site?
Do u know his e-mail?
@ JonT : i've got the instructions for the APEXi in English but don't know exactly what settings to do.
Knudsen r u here? can u give me some help?
07-11-2005, 02:21 AM
alimonos,
Bill is indeed on this site but he hasnt been to active lately. Busy guy you knowSmile pm billzilla
For Knudsen pm knudsen
PMs are greatSmile
07-11-2005, 09:33 AM
hmmz what you could try is to open the tps air screw around 1600 rpm. Than get a good fuel mixture (maybe to much) and fine tune it. The screw with the co sensorsment is far more than just a screw. Its really a pain in the ass it works by MM. I spend several hours adjusting the little bugger.
And i would advise if you use toyota standard stuff. remove the apexi when doing it. It could mess up settings. so first remove apexi than go adjusting stuff.
07-11-2005, 11:14 AM
Robokill when u say "open the tps air screw" u mean the screw that adjusts the throttle cable? If i change it wouldn't that change the TPS settings? What should i do in that case?
When u say remove APEXi u mean just unplug it or should i change the whole wiring and make it as it was?
THanks guys.
  Shim size for AM cams kazi 4 7,290 12-18-2017 05:34 PM
  Torque settings kazi 4 10,334 03-28-2017 12:15 AM
Last Post: kazi
  Toda Cams Alex170984 7 11,245 02-11-2017 05:50 PM
Last Post: Alex170984
  20V cams - CATCAMS vs KELFORD? Grant 19 45,823 11-19-2015 07:45 AM
Last Post: hachirokkos
  cams cams cams megabob 60 72,626 12-31-2013 01:19 AM
Last Post: gze spec
