Vacuum Sensor/line hook up help.
04-20-2008, 09:03 AM
Don't loop the idle-up tubes....
Quote:Picture 3: 4 & 5 are coolant feeds for the waxstat. 1 & 2 I think are for
the power steering( block these off), 3 goes to the aircon idle up solenoid
(picture 5, specifically the F [vacuum] outlet), the other outlet on this valve
(e) goes to the airbox.
This pic (#3) is a perfect example of what you should NOT do with
your unused idle-up tubes. The P/S idle-up valve allows air to pass from
one of those tubes to the other when the steering is on the lock stop. If
you loop them as shown in the pic, air will be constantly flowing from one
to the other, and you will have a big uncontrolled air leak around the
throttle blade. Your idle will be permanently raised, and you will not be
able to adjust it down.
Always block both tubes off separately if you don't have P/S.
Cheers... jondee86
Messages In This Thread
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
[] - Nanaki - 04-14-2008, 11:52 PM
[] - Nanaki - 04-16-2008, 06:29 AM
[] - banpei - 04-16-2008, 04:20 PM
[] - parrot - 04-17-2008, 05:14 PM
[] - Nanaki - 04-17-2008, 09:22 PM
[] - Nanaki - 04-17-2008, 09:27 PM
[] - parrot - 04-18-2008, 01:20 AM
[] - Nanaki - 04-18-2008, 06:13 AM
[] - parrot - 04-18-2008, 06:28 AM
[] - F0Bman - 04-18-2008, 08:24 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
Don't loop the idle-up tubes.... - jondee86 - 04-20-2008 09:03 AM
[] - parrot - 04-20-2008, 04:21 PM
Big Grin map sensor cheating? fdsjakl890 8 3,809 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,090 05-23-2022 10:00 PM
Last Post: The Doctor
  fuel line hose from the pump Wikizz 4 8,304 10-16-2017 07:11 PM
Last Post: jdm86gtz
  US-spec vacuum hard lines LordTD 2 6,917 04-27-2015 07:18 PM
Last Post: Project D
  AE86 Engine Coolant Temp Sensor izanagi 8 24,518 09-06-2014 05:47 PM
Last Post: izanagi
