Vacuum Sensor/line hook up help.
04-20-2008, 08:50 AM
Do you wash and wipe ??
Quote:Now Last But not least. ( I hope ) I also see that just after a black I have this plug on my car. The red/black wire comes the loom under the fuse/relay box, and is a switched power supply. That is, it has 12 volts coming from the fuse box end when the ignition is "ON". As I recall. it runs to one of the centre pins on an accessory plug located next to the ECU. This accessory plug is also connected to the wipers, screen washer and variable resistor. Cheers... jondee86 |
| Messages In This Thread |
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
So many questions... so little time :)) - jondee86 - 04-17-2008, 09:00 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008 08:50 AM
Don't loop the idle-up tubes.... - jondee86 - 04-20-2008, 09:03 AM
| map sensor cheating? | fdsjakl890 | 8 | 4,276 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 9,785 |
| fuel line hose from the pump | Wikizz | 4 | 8,641 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
| US-spec vacuum hard lines | LordTD | 2 | 7,144 |
04-27-2015 07:18 PM Last Post: Project D |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 25,074 |
09-06-2014 05:47 PM Last Post: izanagi |
