Vacuum Sensor/line hook up help.
04-18-2008, 06:13 AM
Sorry for not saying so before but my AE86 was a USDM GTS not a SR5.. The Japanese engine I got did not come with any of the VSV or A/C stuff. The ones I have pictures of are ones from my GTS that was removed when the GTS Engine was pulled.. The A/C Idle up ( Right side of the picture ) still has the plug in the engine bay. However the VSV ( Left on the picture ) has no place to plug into now? The plug for it went with the GTS engine harness.. Do I need to rewire something or still contact the person you mentioned above even though I am not using a Sr5?
Also an update on the cranking and firing of the engine.. I have found out its the pickup coils in the distributer and long story sort I am going to need a whole new distributer for other reasons. So when I find one for a 4ageu then that might fix that problem... Im going to try and reg for that forum so I can check that out though. |
| Messages In This Thread |
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
So many questions... so little time :)) - jondee86 - 04-17-2008, 09:00 AM
[] - Nanaki - 04-18-2008 06:13 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
Don't loop the idle-up tubes.... - jondee86 - 04-20-2008, 09:03 AM
| map sensor cheating? | fdsjakl890 | 8 | 4,318 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 9,860 |
| fuel line hose from the pump | Wikizz | 4 | 8,662 |
| US-spec vacuum hard lines | LordTD | 2 | 7,167 |
04-27-2015 07:18 PM Last Post: Project D |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 25,120 |
